23818 Discussions
this computer does not meet the minimum requirements for installing the software
JCHOI22
I also have this problem. what kind of driver should I install?
My spec/
WINDOW 7 PRO 64 bit
INTEL CORE i7-4770K CPU @ 3.50 GHz
NVIDIA GeForce GTX 660
SYSTEM BIOS
JCHOI22
My computer is desktop
Kevin_M_Intel
Hi JAY123,
Please note that as soon as you connect a PCIe card on the system, the onboard graphics will be disabled automatically. The reason why you are getting this error message is that you have the discrete card connected to the system or the driver you are trying to install is not the correct one.
You can try installing this driver:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22842&lang=eng&OSVersion=Windows%207%20(64-bit)*&DownloadType=%0A%09%09%09%09%09%09%09Drivers%0A%09%09%09%09%09%09
In the case you are still having problems to install the driver, I recommend you disconnecting the video card and try installing the driver again.
