23526 Discussions
this software does not meet the minimum requierments for installing this softwate
IKorn3
Hello everyone!
So i recently bought an Intel i5 3570 ..
I wanted to use the built in graphics chip because my video card is pretty old and not so good as the graphics chip.
When i tried to install the drivers then it showed me - "this software does not meet the minimum requierments for installing this software"
I tried to install 32 bit and 64 bit but none of them worked :S
I tried to install this : https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22842&lang=eng&OSVersion=Windows%207%20(64-bit)*&DownloadType=Drivers Download Center
This :https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22840&lang=eng&OSVersion=Windows%207%20(32-bit)*&DownloadType=Drivers Download Center
And this: https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22842&lang=eng&OSVersion=Windows%207%20(64-bit)*&DownloadType=Drivers Download Center
And everyone of these showed the same thing :S I really want to get it working...
Picture of my computer stats - http://www.upload.ee/image/3575065/sacv.PNG http://www.upload.ee/image/3575065/sacv.PNG
RThor2
I had this problem and it turned out that I needed to get the Graphics Driver from the website of my Motherboard manufacturer, rather than the Driver's from Intel's site.
Also it was only after downloading and installing the Graphics Drivers from my motherboard manufacturer, would the Utility to detect the state of your drivers, that is on Intel's site, finally work for me.
IKorn3
I have tried that and if i wanted to install the VGA driver then the exact same error came up.
Kevin_M_Intel
Sorry to hear that. I recommend you trying the driver:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22842&lang=eng&OSVersion=Windows%207%20(64-bit)*&DownloadType=Drivers https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22842&lang=eng&OSVersion=Windows%207%20(64-bit)*&DownloadType=Drivers
In the case you are still getting the message, I recommend you contacting the computer system manufacturer since it seems your computer has switchable graphics and may require a custom driver from them.
IKorn3
Still the same error with that driver...
And my computer is slef put together.
IKorn3
Kevin_M_Intel
IKorn3
I downloaded it, and tried to install it but still the same error came up.
I'm so frustrated why doesn't anything help?
Kevin_M_Intel
Hi WhiteWidow,
You mentioned at the top that you are using a video card. Please disconnect the video card and try installing the driver again.
IKorn3
How?
When i disconnect it then i cant plug it in to my motherboard because it wont work, only a black screen will come..
Kevin_M_Intel
Hi WhiteWidow,
At this point I am afraid that I do not know the processor model you have therefore I do not know if it has or not onboard graphics.
Assuming that the processor has onboard graphics, My best recommendation is to remove the video card you have connected to the computer. By doing this we can verify if the Intel® graphics controller works fine or not. In the case that the onboard graphics is not working, If possible test another processor so we can discard issues with the one you have.
