23081 Discussions
valorant & counter strike 2'de düşük fps ve takılma sorunu
bahtsızbedevi
İyi günler,
Valorant ve counter strike oynarken ani fps düşüşleri ve takılma sorunu yaşıyorum sürücüleri kontrol etttiğimde herhangi bir sorun gözükmüyor yardımcı olabilecek biri var mı?
Şimdiden iyi forumlar
( Intel Arc B580 ekran kartı işlemci intel i3 13100f)
ArchieD_Intel
Hi bahtsızbedevi,
  • When did the issue start? Was it after a specific driver update or game patch?
  • What are the troubleshooting steps that you tried so far?
  • Is the Resizable Bar enabled?
  • Have you used DDU to completely remove all residual drivers and installed a new one?
  • Have you tried adjusting the graphics settings?
  • Could you provide a screenshot of your in-game display and graphics settings?
  • Which gaming platform did you use to download the game?
I would also like to obtain 3 CapFrameX log to thoroughly analyze the FPS performance. Kindly ensure that the game would run for a minimum of 2 minutes each.
Additionally, to gain a comprehensive understanding of your system, please use the System Support Utility (SSU). This tool will generate a text file compiling all your system information. You can follow the instructions at this link and send the text file here. Help Guide for the Intel® System Support Utility.
Archie D.
ArchieD_Intel
Hi bahtsızbedevi,
Archie D.
ArchieD_Intel
Hi bahtsızbedevi,
Archie D.
