23806 Discussions
vga support intel hd 540
racht2
I have an intel nuc6i5syk and a display with (only) a VGA connector.
I'v tried several mini-dp to vga adapters, but none of them works, why is this?
EstebanA_C_Intel
Hello, Moris:
It is not recommended to use adapters to connect the displays (TV/Monitor) to your unit. Since the video signal is going from analog (VGA) to Digital (DP/HDMI) we cannot assure it is going to work properly.
I was checking some information regarding this, there are active and passive adapters, it seems like active adapters could help in this type of situations.
Esteban C
racht2
The signal is going from digital (dp) to analog (vga), and other people don't seem to have the same problem
EstebanA_C_Intel
Hello, Moris:
Have you checked which are the specific adapters used by the other users mentioned?
Also, you could test doing the following, test a direct connection to DP in the NUC to make sure it works properly and to discard that as the issue.
I look forward to your outcome.
Esteban C
