22895 Discussions
what does it mean? Device PCI\VEN_8086&DEV_
NNige
What does it mean? Device PCI\VEN_8086&DEV_22B1&SUBSYS_363717AA&REV_35\3&11583659&1&10 requires further installation.
Hello niggle:
In regards to your inquiry I just wanted to let you know that the message is normal and has no significant meaning at all, even though it can be confusing and previous Windows versions did not show something similar. If there is an entry called "Device Installed" somewhere under it in the list, then you can assume that the driver for your device is properly installed.
But just to make sure, is there any problem with your PC is it working properly?
Any questions please let me know.
Alberto
NNige
Thank you for putting my mind at rest.
I am using a brand new computer and thought the information might be critical to its smooth running. (I was having a number of teething problems but all is well, now).
The new PC is an all-in-one Lenovo C20 with Windows 10 pre-installed. I am finding it very difficult compared with Windows XP, mainly because Windows 10 seems to be over-provided with user options. However, it also seems to have a poor memory for the choices I make, so a double whammy.
Again, thank you for your kind interest in my enquiry.
niggle
Hello niggle:
Thank you very much for letting us know that information.
You are welcome, yes, there is a big difference on the user options from Windows® XP to Windows® 10, but I am pretty sure at some point you will get used to it and you will end up using it with no problems.
Any other inquiry, do not hesitate in contact us again.
Alberto
darrin1
thank you
computer got connecting to internet wirelessly and code is getting deleted then install?
Hello niggle:
I just wanted to check if the information posted previously was useful for you and if there is something else that we can assist you with?
Alberto
darrin1
thank you all, helpful just trying to work why can't connect to internet wirelessly.
but thank you all for replying and helping
darrin1
if you would know why not connect wirelessly?
Thank for your help
