23821 Discussions
which graphic card should i get
hi my pc config is as follows
mother board: intel DG41RQI
prcsr: intel c2d e7500
ram : 2gb
i dont have any external graphic card , i want someone to suggest which graphic card i have to use so that i can play some high end or normal gaming
my monitor res 1366*768
i love if i can get a graphic card so that i can have some good gaming at my screen resolution
RGiff
Honored Contributor I
Alot of this depends on your budget. you can get a pretty good card for $140.00 to $150.00. or go for broke and spend $400.00. It's a choice , a good HD4770 is a nice mid range card , or if you can crossfire two HD5770s will work well , But you would need a 850Watt PSU , You never want to add a big card and not have enough power to run it .
iam good with 140$ but i have a 450w psu is that ok
would it be better if i take pci x16 or just pci
my config: intelG41 chipset
RGiff
Stick with the ,,, PCI-E X16-2.0 that will give you the best band width. You still did say weather that board can do crossfire?? Or does it have only one PCIE-16.2.0 slot??
RGiff
Well I looked it up you only have a single PCIEX16.2.0 slot ?? sorry No crossfire. Let me look at Newegg and than I can make a recomdation in your price range that will work with your 450Watt PSU.
RGiff
Here is a pretty good card that needs no extra power connections I have two of these , I bough for a crossfire set up but the board I was using will not do a software crossfire it needed a bridge which these cards don't have ,But as a single card they are great. Go to Newegg search part # N82E16814102930 ,.. It's a Saphire HD5570 1GB DDR3 Mem. ought to serve you well .
