22939 Discussions
why won't Graphic update x.x.x.5074 load to my com,puter? it is the one recommended by Drive & Support assistant.
kmitc2
​this is my system info:
Latest version: x.x.x.5074
Installed Version: x.x.x.5067
Update available
Adapter CompatibilityIntel Corporation
Video ProcessorIntel® HD Graphics Family
Resolution1920 x 1080
Bits Per Pixel32
Number of Colors4294967296
Refresh Rate - Current60 Hz
Refresh Rate - Maximum75 Hz
Refresh Rate - Minimum59 Hz
Driver ProviderIntel Corporation
Driver Version10.18.14.4029
Driver Date11/18/2014
Adapter DAC TypeInternal
Adapter RAM1.00 GB
AvailabilityRunning at full power
StatusThis device is working properly.
LocationPCI bus 0, device 2, function 0
Device IdPCI\VEN_8086&DEV_0412&SUBSYS_2AF7103C&REV_06\3&11583659&0&10
AlHill
What is the model number of your device/motherboard?
What is your processor model number?
Are you a laptop or desktop?
What version of windows 10 are you using? 1903? 1909?
Doc
kmitc2
Windows 8.1 Processor Intel(R) Core(TM) i5-4440 CPU @ 3.10GHz, 3101 Mhz, 4 Core(s), 4 Logical Processor(s) desktop best i could find on motherboard is: BaseBoard Manufacturer Hewlett-Packard BaseBoard Model Not Available BaseBoard Name Base Board here are the specs i could find on my computer: - don't know what else i can add except the driver update doesn't load, gives error it's not for my computer specs ... OS Name Microsoft Windows 8.1 Version 6.3.9600 Build 9600 Other OS Description Not Available OS Manufacturer Microsoft Corporation System Name MUSIC-PC System Manufacturer Hewlett-Packard System Model 700-214 System Type x64-based PC System SKU F3E00AA#ABA Processor Intel(R) Core(TM) i5-4440 CPU @ 3.10GHz, 3101 Mhz, 4 Core(s), 4 Logical Processor(s) BIOS Version/Date AMI 80.20, 10/31/2014 SMBIOS Version 2.7 Embedded Controller Version 255.255 BIOS Mode UEFI Platform Role Desktop
AlHill
You may want to try and manually install the driver:
https://www.intel.com/content/www/us/en/support/articles/000005629/graphics-drivers.html
Doc
kmitc2
Thanks for that bit of info ... and the directions, but i've tried that before, and again after your email.... here's what i get ..... "The Driver being installed is not validated for this computer. Please obtain the appropriate driver from computer manufacture. setup will exit. would you like new information. Click yes to be directed to intel website." do that and it says win64_15.36.37.5074 is the driver for my 64x win 8.1 system 4 hours later ... i give up.
kmitc2
found an old tutorial online - walked thru those steps (again) and was finally able to manually update appreciate your help and concern. looks like this is the last update (security) for this product .... have a good one.
n_scott_pearson
Yes, absolutely. There will be no subsequent drivers or BIOS releases for this board/processor (at least from Intel): (a) only Windows 10 64-bit will be supported moving forward and (b) the board and processor are six years old and were discontinued by Intel and HP years ago.
