22005 Discussions
will nuc x15(11th) be able to be replaced with a 4k120hz screen?
Supernova
my laptop is nuc x15 with i711800h, i want to replace my screen with 4k 120hz. i wish to know does my laptop can work fine with 4k 120hz screen?  I mean replace the screen, not extend a external screen.
ACarmona_Intel
Hello Supernova,
When you say "replace the screen," are you referring to the resolution of the screen? Please clarify what specific concern we have so that we can offer you the right answer.
And by the way, may I know the complete model of your NUC laptop? We will use it for further research.
We look forward to your response!
Thank you, and have a great day ahead!
Carmona A.
Supernova
My laptop's model is nuc-x15-laptop-kit-lapkc71e. When i said "replace the screen", the precisely meanning was if i could buy a 4k 120hz screen to replace the original?
Thanks for your reply
MUC
Valued Contributor III
Intel NUC X15 Laptop Kit Product Specification
LAPKC71E >> Narrow Bezel IPS 15.6” 2560 x 1440, 16:9 ratio, 165 Hz
2560 x 1440 @ 165 Hz RGB 8-bit CVT-RB = 97% HBR2 = 65% HBR3
3840 x 2160 @ 120 Hz RGB 8-bit CVT-RB = 100% HBR3
eDP 1.4b is based on DisplayPort 1.3 and theoretically supports HBR3. However, it depends on which screen you want or can even mount. There should also be warranty period left on your laptop, which would be lost if there is tinkered with it.
Considering the functional risk with an unbranded/random replacement screen, I wouldn't recommend that but use a cheap external monitor, e.g. Samsung Odyssey Smart G70B (28“) Gaming Monitor ($500), which is then directly driven by the Nvidia GeForce RTX 30X0 via HDMI:
ACarmona_Intel
Hello Supernova,
I agree with the suggestion of MUC, one of our valued contributors. Please check out its reply and let us know if you have any additional questions.
Carmona A.
ACarmona_Intel
Hello Supernova,
We would like to know if you have already checked on the suggestion of MUC, one of our valued contributors. If not, please check out its reply and let us know if you have any additional questions.
Carmona A.
ACarmona_Intel
Hello Supernova,
We are checking in with you, as we have not heard any response from you.
Thank you, and have a great day!
Carmona A.
Intel Customer Support Technician
