23704 Discussions
wtf raid
First, I looked through the forum history and couldn't find my solution. If this has all ready been covered I apologize.
I'm trying to set up raid 0 on a fresh install. When I go to install the drivers on setup I get the following error:
"To continue installation, use the Load Driver option to install 32-bit and signed 64-bit drivers. Installing an unsigned 64-bit device driver is not supported and might result in an unusable windows installation"
I am using the ICH10R chipset, I have enabled RAID in the bios, and then created the raid 0 array in the RAID bios.
I am using Windows 7 Ultimate 64 bit, and I have used the 64 bit raid drivers from the install CD, from my mobo's website, and from the intel website (assuming I should be using Intel Matrix Storage Manager).
The array is detected by windows; however, It won't let me install it without the third party drivers.
When I download the drivers, I unzip the files and burn them to a cd
I've never set up a raid before, are these the right drivers? what am I doing wrong?
if screen shots would help ask and ill take some
I figured out the problem.
I was assuming since windows wouldn't install on my RAID array that I needed to install the raid drivers. This assumption was wrong.
I kept getting the error "Setup was unable to create a new system partition or locate an existing system partition" when trying to install on it.
Solution: You HAVE to have your RAID array as the FIRST boot device. Not your CD-rom. Hair pulling problem, simple solution.
