23791 Discussions
xvYCC won't stay enabled
Every time I turn off my TV or switch inputs on my reciever, the xvYCC option becomes disabled and I have to reenable it. Has anyone else seen this? Any suggestions?
System Info:
Intel(R) HD Graphics 3000 Report Date: 8/6/2011Report Time[hr:mm:ss]: 11:56:11Driver Version: 8.15.10.2372Operating System: Windows 7 Service Pack 1(6.1.7601)Default Language: English (United States)DirectX* Version: 10.1Physical Memory: 8098 MBMinimum Graphics Memory: 64 MBMaximum Graphics Memory: 1696 MBGraphics Memory in Use: 115 MBProcessor: Intel64 Family 6 Model 42 Stepping 7Processor Speed: 3400 MHzVendor ID: 8086Device ID: 0122Device Revision: 09 * Processor Graphics Information * Processor Graphics in Use: Intel(R) HD Graphics 3000Video BIOS: 2111.0Current Graphics Mode: 1920 by 1080 * Devices Connected to the Graphics Accelerator * Active Digital Televisions: 1* Digital Television * Monitor Name: Generic PnP MonitorDisplay Type: DigitalGamma Value: 2.2DDC2 Protocol: Supported Maximum Image Size:Horizontal: 32.28 inchesVertical: 18.11 inches Monitor Supported Modes:640 by 480 (75 Hz)640 by 480 (60 Hz)640 by 480 (72 Hz)720 by 400 (70 Hz)800 by 600 (72 Hz)800 by 600 (75 Hz)800 by 600 (56 Hz)800 by 600 (60 Hz)1024 by 768 (75 Hz)1024 by 768 (70 Hz)1024 by 768 (60 Hz)1280 by 720 (60 Hz)1280 by 1024 (60 Hz)1400 by 1050 (60 Hz)1600 by 1200 (60 Hz)1920 by 1080 (60 Hz)1920 by 540 (60 Hz) Display Power Management Support:Standby Mode: Not SupportedSuspend Mode: Not SupportedActive Off Mode: Supported Raw EDID:00 FF FF FF FF FF FF 00 4D 10 FB 0F 00 00 00 00 FF 11 01 03 80 52 2E 78 2A 1B BE A2 55 34 B3 26 14 4A 52 AF CE 00 D1 C0 A9 40 90 40 81 80 01 01 01 01 01 01 01 01 01 1D 80 18 71 1C 16 20 58 2C 25 00 34 CC 31 00 00 9E 01 1D 00 72 51 D0 1E 20 6E 28 55 00 34 CC 31 00 00 1E 00 00 00 FC 00 53 48 41 52 50 20 48 44 4D 49 0A 20 20 00 00 00 FD 00 37 4C 0F 4B 11 00 0A 20 20 20 20 20 20 01 B6 02 03 3B 74 4F 90 20 05 04 03 02 07 06 01 0E 0F 0A 0B 23 24 35 09 7F 07 0F 7F 07 15 07 50 3E 1F C0 57 06 00 67 54 00 5F 54 01 83 4F 00 00 E3 05 03 01 68 03 0C 00 32 00 B8 2D 00 8C 0A D0 8A 20 E0 2D 10 10 3E 96 00 C4 8E 21 00 00 18 8C 0A D0 8A 20 E0 2D 10 10 3E 96 00 67 CC 21 00 00 18 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A5 * Other names and brands are the property of their respective owners. *
Anyone?
I have submitted a support ticket. I'll post a reply if I get a solution.
JMcKa
I am experiencing a very similar situation with an Intel DH67BL connected to a Denon AVR - Panasonic TV.
Any news on a fix?
The response I received was that this was a known issue and the engineering team was working on it. So far there's only been two releases of the drivers for Win7 x64 (inital version 15.22.1.64.2361 from April and version 15.22.50.64.2509 in September). The new version did not fix the problem. I'm not very optimistic that we'll get a fix...
JMcKa
In itself it is a fantastic step in the right direction for a true Htpc. Let's hope Intel figure this out...
TRami1
This is happening to me as well, on Windows 8. I don't have a receiver. It happens when I turn off the TV. The TV remains connected as far as its status when powered off.
Allan_J_Intel1
Hello Timothy Ramich,
Can I have the driver version you are currently using on the computer? also the operating system version?
In order to check the driver version open graphics control panel and look for options and Support on the left panel then check Information, there you can find the graphics version
TRami1
Allan_J_Intel1
I will forward this thread to the engineering department, if more information is needed, I will come back here and post some updates.
Allan
TRami1
I am thinking connecting to my computer remotely (RDP) is what triggers this.
TRami1
OSoel
Have the same problem. Pretty annoying
OSoel
Would it be possible (as a workaround) from a command line to change the xvYCC setting or a registry key that you could change on every start up?
Allan_J_Intel1
Thanks for the feedback, I will forward the information to our engineering department, I will come back here and post some updates.
NKeef
HI Allan,
Have there been any updates to this issue? I too have am not able to get xvYCC RGB working correctly with my DENON AVR using the Intel HD 3000 graphics on my Sandy Bridge processor in Win7. If I plug in a discrete graphics card such as an ATI or NVidia xvYCC works fine. This has been a very frustrating issue for me that renders the on board graphics of no use. The fact that this issue hasn't been resolved in years is also very frustrating.
Please let me know if I can be of any help in troubleshooting this issue or if you need any additional information.
Nat
OSoel
Downloaded and installed the lastest driver - https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22842&lang=eng&OSVersion=Windows%208%2C%2064-bit*&DownloadType=Drivers Download Center
Problem solved 🙂
From the relase notes:
The Intel Graphics Control Panel now keeps the advanced HDMI settings such as Quantization and xvYCC persistent between reboots.
TRami1
Problem not solved for me. No new drivers for my hardware since March.
DArce
Valued Contributor III
Timothy, could you please post the graphics report generated through the Intel(R) Graphics Media Accelerator control panel as illustrated on this article:
http://www.intel.com/support/graphics/sb/cs-009476.htm Graphics | Intel(R) Graphics Driver Report
Do this while using the latest video driver and if you still experience the xvYCC problem with that latest driver.
