Intel® ARC™ Graphics
3468 Discussions
İntel Arc A750 Ekran kartında 4:3 En Boy Oranına Aldığımda 60 hz Sabit Kalıyor
Zgin
Merhaba Öncelikle Sistemim
Amd Ryzen 5 5600 İşlemciye Sahibim Monitörümü 4:3 En Boy Oranında Kullanmak İstediğimde 60 hz Ekran tazeleme Hızında kalıyor genellikle cs2 oynarım ve dp portla bağladım normal kullndığım hz 200 oyunda veya masaüstünde fark etmeksizin 4:3 Ekran oranına aldığımda 60 hz sabit kalıyor ve 200 hz seçenekleri gözükmüyor Monitörüm
E target=_blankxcalibur 27” Monitör Modeli - Casper Bu Ekran kartını beğeniyorum lakin böyle hatalar can sıkıyor ilgilendiğniz için teşekkür ederim
VonM_Intel
Hi, Zgin.
Thank you for posting in our Community.
Please be informed that I have used a web translation tool to translate this response hence, there may be some inaccurate translation.
It seems you're facing an issue where your monitor is locked at a 60Hz refresh rate when using a 4:3 aspect ratio, despite normally operating at 200Hz. This can be particularly frustrating, especially when you're aiming for optimal performance in games like CS2. The Intel Arc A750 graphics card has specific capabilities when it comes to monitor resolutions and refresh rates.
Maximum Supported for Display Port (DP): It can handle up to 7680 x 4320 at 60 Hz via Display Port. In summary, while the Intel Arc A750 doesn’t specifically mention support for a 200 Hz monitor, it can handle high resolutions and refresh rates. If you have a specific monitor in mind, I recommend checking its compatibility with the Intel Arc A750 directly with the manufacturer or retailer.
Von M.
VonM_Intel
Hi, Zgin.
I trust you're doing well.
I have not heard back from you, we will close this inquiry now. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Von M.
