안녕하세요, 제목의 내용과 같은 문의입니다.
13세대 CPU까지는 인텔 i5 CPU라는 문구를 활용했는데,
지금은 Ultra5로 명칭이 바뀐 부분 관련하여
13세대 이전의 CPU들은 U5,Ultra5라는 문구를 사용할수 없는건가요?
Hello cokorysh,
영어로만 지원해 드릴 수 있으며, 원하신다면 해당 언어를 지원하는 다른 팀으로 연결해 드릴 수 있습니다. 이 응답을 번역하기 위해 웹 번역 도구를 사용했기 때문에 일부 부정확한 번역이 있을 수 있습니다.
To answer your inquiry regarding the naming differences between Intel® 13th Gen and 14th Gen processors.
You're absolutely right—prior to the 14th Gen, Intel used the Core i5 branding for mid-tier CPUs. With the launch of the Intel Core Ultra series, starting from the 14th Gen Meteor Lake architecture, Intel introduced a new naming convention: Ultra 5, Ultra 7, and Ultra 9.
To clarify:
- Ultra 5 is not a rebranding of older i5 processors.
- It represents a new generation of CPUs built on a different architecture, featuring enhanced AI capabilities, improved power efficiency, and integrated Intel® Arc™ graphics.
- Pre-14th Gen CPUs, including 13th Gen and earlier, do not support or carry the Ultra 5 designation.
So, while both Core i5 and Ultra 5 target similar performance tiers, they belong to distinct product families and are not interchangeable in naming or feature sets.
Let us know if you have other concerns or clarifications.
Earl E.
Hello cokorysh,
I wanted to check if you had the chance to review my previous post. Please let me know at your earliest convenience so that I can determine the best course of action to resolve this matter.
Earl E.
Hello cokorysh,
Earl E.
