- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
Graphics: B580 sparkle steel legend
CPU: intel 14700kf
Board: msi X690
RAM: ddr 4 3600 32GB
As per title, first of all the latest drivers were not following the previous naming scheme being called simply gfx_win_101.6559.exe instead of following the previous driver naming schemes of gfx_win_101.6557_101.6262.exe and also coming in 500MB smaller in size compared to the previous average, non the less it was put forward and still is as the latest official driver.
The issue is it (6559), was causing a very annoying pause/lag to opening the start menu in windows 10 and was causing a very noticeable delay in opening vdsc video editor. Nothing was not working, just these things had become slow to load. I tried various other troubleshooting things on the net, the only thing that worked for about 5 seconds was going into task manager and stopping the start process. The start menu opened as it should instantly then became laggy again after about 3 more tries at it. I then reinstalled the previous 6262 driver, all fixed. So whatever process/file those systems are calling that had been changed between the 6559 and 6262 drivers are probably to blame.
Lien copié
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi MVb590,
I'm sorry to learn that you are experiencing issues with your system. Rest assured that I will further investigate on this; to better assist you and determine the most appropriate resolution, could you please provide the needed details listed below:
- May I know if you already tried performing DDU when installing the latest GPU drivers?
Kindly run this on your system so that I can gauge the following peripherals and the driver versions that you have:
Intel® System Support Utility for Windows*
Once finished downloading, open the tool, click on scan (leave the default items checked), click next, then save the system information to a .txt file. Please provide us the .txt file.
Earl E.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Ok, because it would also be pointless without it, I just installed the 6559 driver and here is the scan for it attached.
I am now going to revert back to 6262 as these drivers are unusable with the pause lags that are again present. I do choose clean install when installing drivers as well.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hello MVb590,
I appreciate you sharing us the updated SSU logs.
Rest assured that I will further investigate on the issue that you brought up and will provide you an update on this thread as soon as possible.
Earl E.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hello MVb590.
I appreciate your patience in this matter. The issue is fixed in driver 32.0.101.6632. Please download and install the latest graphics driver version and let us know the outcome to determine if the issue persists
Von M.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi MVb590,
I wanted to check if you had the chance to review the resolution I posted. Please let me know at your earliest convenience so that we can determine the best course of action to resolve this matter.
Earl E.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Oh yes, sorry, total oversight on my end. I did install those drivers and yes, the problem is no longer.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hello MVb590,
Thank you for your response.
I'm happy to hear that update from your end!
Since the issue is now resolve, I will no longer monitor this thread.
You can continue to monitor the performance of your system on the latest graphics driver update, if you encounter any issues or other concerns, please don't hesitate to submit a new question as this thread will no longer be monitored.
Earl E.
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
