Intel® Arc™ Discrete Graphics
3502 Discussions
A370M Not Utilized
JayDez
I am finding an issue with my laptop with an A370M where utilization is negligible (0%), including when powered directly from the wall.
I am on driver version 31.0.101.4369 and the intended game (Minecraft, v 1.19.4) is detected on Arc Control. Additionally, my A370M shows up in device manager, but Arc Control's display tab associates the display with Intel Iris Xe Graphics.
Is there any way to forcibly use the A370M? Sorry if this is a naive question.
Labels (2)
Jean_Intel
Hello JayDez,
In case the issue persists, we would like to ask for the following information:
  • Is this issue present since day one?
  • How are you checking the GPU utilization?
  • Are you using the laptop in performance mode?
  • Also, we would like to ask for more system information, create a system report using the following tools:
  •  Intel System Support Utility (Intel SSU)
    • Download the Intel SSU
    • Open the application and click "Scan" to see the system and device information. By default, Intel SSU will take you to the "Summary View."
    • To save your scan: click on "Next"; then "Save."
  • Intel® Graphics Command Center
    • Open the Intel Graphics Command Center
    • Navigate to the Support tab
    • Select System Diagnostic
    • Click Generate Report
    • Select Save and name the output file.
Jean O.
Jean_Intel
Hello JayDez,
We hope you are doing fine.
Jean O.
Jean_Intel
Hello JayDez,
Best regards.
Jean O.
