- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi all,
Having the above errors appear in Event Viewer at random times whilst using anything utilising DX12. Typically the game will freeze and Crash To Desktop. This doesn't happen under VK/=<DX11 I've already tried using DDU to perform a clean reinstall, however that hasn't worked for me. I am currently using driver version 32.0.101.6795
I am pretty sure that this isn't an issue with my GPU itself, as it behaves fine under Linux/Steam Proton!
Below is an extract from Event Viewer
Fault bucket LKD_0x141_Tdr:6_IMAGE_igdkmdnd64.sys_GEN12_DX12COMPUTE_BBHANG, type 0
Event Name: LiveKernelEvent
Response: Not available
Cab Id: e717bb19-bac8-423f-a1fd-faefd9fa9f8e
Problem signature:
P1: 141
P2: ffffe104daec7010
P3: fffff806751e26f0
P4: 0
P5: ffffe104de5020c0
P6: 10_0_26200
P7: 0_0
P8: 256_1
P9:
P10:
\\?\C:\WINDOWS\LiveKernelReports\WATCHDOG\WATCHDOG-20250526-1527.dmp
\\?\C:\WINDOWS\SystemTemp\WER-4009500-0.sysdata.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER.6eecaf32-c6a7-45a3-a1a3-4530b73803f8.tmp.WERInternalMetadata.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\ReportQueue\Kernel_141_8c9194ab438020cf9ee4b993ac3c2455adaf6d5_00000000_cab_330cc4d8-7281-4f2e-8233-e389d0880923\WPR_initiated_DiagTrackMiniLogger_OneTrace_User_Logger_20240808_1_EC_0_inject.etl
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER.a1b89c15-34df-462d-bfbb-7a8a3cd3b5c0.tmp.etl
\\?\C:\ProgramData\Microsoft\Windows\WER\ReportQueue\Kernel_141_8c9194ab438020cf9ee4b993ac3c2455adaf6d5_00000000_cab_330cc4d8-7281-4f2e-8233-e389d0880923\WPR_initiated_DiagTrackMiniLogger_WPR System Collector_inject.etl
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER.58e69914-9259-421b-a699-d1328221a3f5.tmp.etl
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER.ea6d3b1b-1a4e-4d9c-9af8-caf215a46fee.tmp.csv
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER.61f4c30e-7d1e-4011-9578-b028108b5992.tmp.txt
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER.efa10869-3041-4da2-9013-9d8cc0e18877.tmp.xml
These files may be available here:
\\?\C:\ProgramData\Microsoft\Windows\WER\ReportArchive\Kernel_141_8c9194ab438020cf9ee4b993ac3c2455adaf6d5_00000000_cab_330cc4d8-7281-4f2e-8233-e389d0880923
Analysis symbol:
Rechecking for solution: 0
Report Id: 330cc4d8-7281-4f2e-8233-e389d0880923
Report Status: 268435456
Hashed bucket:
Cab Guid: 0
Cheers!
링크가 복사됨
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi @grbtd,
- Please provide the SSU log report and share it here so I can review your system's configuration.
- Could you let me know the origin of the game? Where did it come from, and where did you download it?
- Could you please share the steps you take to recreate the issue? This will help us understand the context and identify potential solutions.
- We also request that you generate a kernel or complete crash dump and share it with us for detailed analysis.
- When did the issue first occur? is it working fine before?
- Have you made any software or hardware changes to the system recently?
- What troubleshooting steps have you tried so far?
- Have you noticed any signs of overheating in the system?
Warm regards,
Randy T.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Evening Randy,
I've attached the SSU log to this reply. I also have a Kernel Dump, however it is 1.8GB. How would you like this sharing? It may be worth noting I did the dump with nothing running. I can attempt to grab a dump as an application crashes, however it usually CTDs very quickly.
Essentially, from what I can gather, any DX12 accelerated application seems to crash at some point in time, completely random as to how long the application stays up, sometimes an hour or so, sometimes just a few minutes. In some cases, I am able to pass a DX11 flag, so that a game uses DX11 rather than 12, and this seems to keep it stable. This leads me to believe that it's isolated to DX12.
The GPU works great under Linux. No such crashes or anything, and Vulkan/DX11/DX9 performance under Windows is fine, and is stable. Again, just seems to be DX12.
I've attempted a clean install of not only the Driver, but Windows also. Neither have made the issue go away. Thermals seem fine, the card is happy to go up to 220+W if I want it to.
Thanks for jumping on this. I really appreciate it. Let me know if you need more from me.
Ollie
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi @grbtd,
To assist you effectively, I would like to clarify a few points.
You mentioned applications running in DX12. To ensure a focused investigation, I kindly ask you to specify the particular game or application that tends to crash under DX12. Please note that I can only investigate one issue per thread, which means focusing on one application at a time. This will allow us to concentrate on that specific issue and determine the best course of action.
Please feel free to share the crash dump via email. I will send you an email shortly after you read this thread update to facilitate the process.
Our main goal is to understand why the software is crashing in DX12 mode. Once you confirm the specific application, I can laser-focus on the issue and work towards a resolution.
Thank you for your patience and cooperation. I look forward to your response.
Warm regards,
Randy T.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi @grbtd,
Warm regards,
Randy T.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi @grbtd,
Since I haven't heard from you, I will proceed with closing this case. Please note that it will no longer be monitored. However, you may submit a new ticket if you need further assistance in the future.
Warm regards,
Randy T.
