HI,
#1: ARC Control panel will show the current driver version for the integrated HD P630 video instead of the ARC A750 driver version. You should probably fix the ARC Control Panel to show the ARC driver version instead of the HD P630 version.
#2: Please spend a bit more time refining the OpenGL drivers. I play BAR (Beyond All Reason) which uses OpenGL. Good news is the ARC drivers work. Bad news is the bump mapping and water shaders don't seem to function correctly.
Cheers!
Hello Robotsmasher0
Thank you for posting on the Intel® ARC™ Graphics Communites. I am sorry you are experiencing discrepancies in the information being displayed on the Intel® Arc™ Control Software. Please share with us the following information:
- Share a screenshot of Intel® Arc™ Control Software showing this issue.
- Create a log file with the Intel® System Support Utility and attach it.
In regard, to the other issue that you mentioned about OpenGL and the game Beyond All Reason, please open a new thread in order to keep one issue per thread and to prevent confusion in the troubleshooting steps as well as for other community members that might be experiencing similar issues.
Hugo O.
Hello Robotsmasher0
I hope you are doing fine.
Hugo O.
Hello Robotsmasher0
I have not heard back from you. So I will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Hugo O.
