Intel® ARC™ Graphics
3442 Discussions
Acer A770 QSV encoder error can't record/stream
CookTurtle
First, I'm a Taiwanese.My English may not professional.
The problem is after I install the latest driver after few days my discord can't stream the stream preview black screen and circle around. When this situation happened same time open OBS and click record it will display a error window like the picture.And when I start game It will display a error like picture2. If I want to fix it I need to reinstall the driver. It will reslove few days. Later that situation will happend. Always reinstall the graphic driver is stupid I need a solution to resolve the problem.Or my graphic card is broken I have no idea what happend. Need someone help me.
I try the following solution:2112
Use DDU to uninstall the graphic driver (The problem still happend after few days)
Use DriverStoreExplorer to uninstall all driver about Intel Graphic and Graphic Card Driver and old version driver (The problem still happend after few days)
Use clear install in Intel ARC driver install process
BIOS RESIZE BAR "ENABLE"
CPU:i5 13400F
RAM:T-Force Vulcan Z DDR4 3200MHZ 16G*2
MB:MSI PRO B660M-A DDR4
OS:Win10 professional edition 22H2
Graphic Card Driver Version:31.0.101.4382(latest)
In the end I find a similar discussion thread in Intel community but the article poster update driver and resolve problem
https://community.intel.com/t5/Intel-ARC-Graphics/Cannot-stream-record-render-using-Intel-Arc-A770-s-QuickSync/m-p/1427830
Labels (2)
Hugo_Intel
Hello CookTurtle
We noticed this issue is related to your other thread with the title A770 QSV encoding error can't record and stream. Please continue posting on the original thread. In order to prevent duplicate topics we will be closing this thread.
Hugo O.
