Intel® Arc™ Discrete Graphics
3692 Discussions
Alchemist A770 update problem
Noahs_ARC
I have the Intel (Founders?) Alchemist Arc770 with 16 GB on-board for about 18 months in my "white box" desktop. Over that time, I have received an update from Intel and used the auto update method successfully....until about 3 months ago, when it fails with a 999 error. This has happened with every update attempt since then. I have checked Device Manager-->Display Adapters-->Intel Arc A770; right click -->update driver-->search automatically-->you have the best driver already
ARGH!! Help?
VonM_Intel
Hi, Noahs_ARC.
Thank you for posting in our Community and for providing the details regarding the issue with your Intel® Arc A770 graphics card. The 999 error typically indicates a general installation failure, and since it has persisted across multiple update attempts, I'd like to take a more targeted approach to isolate the cause. To assist further, could you please confirm the following:
  • Have you tried manually downloading the latest Arc GPU driver from Intel’s website and installing it directly (bypassing the update tool)? If so, what was the result?
  • Have there been any significant system changes recently (e.g., Windows updates, BIOS changes, software installs) around the time the issue started?
  • Do you receive any additional details or logs with the 999 error, or is it a generic failure message with no context? If possible, could you please share a screenshot capturing these errors?
  •  If you've already taken any steps to resolve this issue before reaching out, please share those details with me so I can avoid repeating any unnecessary actions.
Additionally, I'd like to delve deeper and verify specifics like the graphics models, precise driver versions, and any system errors. Utilizing the Intel SSU tool will enable me to collect detailed information about your system setup, which could aid in identifying the underlying cause of this issue. For your privacy and security, I have already sent you an email to collect the SSU reports. Once I receive the logs, I can investigate further and provide better assistance.
Have a nice day!
Von M.
VonM_Intel
Hello, Noahs_ARC.
Von M.
VonM_Intel
Hello, Noahs_ARC.
I have not heard back from you, so I will close this inquiry now. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Von M.
