Intel® Arc™ Discrete Graphics
3679 Discussions
Arc Control Center Driver Rollback Issue
Ayun
Hi there,
After installing the latest Arc driver 31.0.101.5081 it seems as if there is an issue concerning  Windows checking for updates and a forced but "fake" driver rollback to version 31.0.101.4577 shown in Arc Control Center.
Arc driver 31.0.101.5081 was installed using DDU in Save Mode and everything seemed to be working fine. On the next day, while using Blender, Arc Control opened up and stated a driver update displaying 31.0.101.4577 as the new driver and demanding a restart. Time of occurrence corresponds roughly with last logged Windows Check for Updates. When navigating to restart the system Win11 also showed the corresponding pending update iconography.
So I checked the driver versions after restart in...:
...Device Manager: Device Manager still shows Version 31.0.101.5081 as the driver in use
...GPU-Z: Still shows 31.0.101.5081 as the driver
...Intel Driver & Support Assistant: Shows 31.0.101.5081 as the installed driver, but also displays a text information concerning a "customized computer manufacturer driver" referring me to contact Gigabyte for the latest driver. The thing is Gigabyte is the manufacturer of my MoBo not my DGPU and I am running their latest version of Bios. ASROCK which is the manufacturer on their website explicitly states to use the official Intel drivers.
Arc Control Center displays 31.0.101.4577 and when checking for updates says I am on the latest driver. So the ACC issue somehow seems to be related to the information displayed by Intel Driver & Support Assistant.
Relevant system information:
CPU: 13600K
DGPU: ASRock A770 Challenger 16GB OC
MoBo: Gigabyte Z790 UD AX
OS: Win11 Home 64 Bit 23H2
DGPU Optimization:
I do use MoBo ASPM and Windows Power Saving modifications as communicated by Intel for improved power consumption.
The questions for me are:
Will this result in performance issues/ system instabilities?
Is it solely a software related read out issue not interfering with the use of 31.0.101.5081?
All the best
Hugo_Intel
Hello Ayun
Thank you for posting on the  Intel® ARC™ Graphics Communites.
In regard to this issue as long as the device manager displays the correct driver version -in this case 5081- is installed there should not be any problem. Based on your explanation of the issue driver 4577 shows up just as a driver update suggestion, perhaps a driver recommended by the motherboard manufacturer as pointed out.
Something you can try would be to uninstall the Intel Driver & Support Assistant(IDSA) using this uninstaller, once uninstalled reinstall the latest version of IDSA.
If you continue to experience the issue, please share with us a screenshot of the message you see on the IDSA website.
Hugo O.
Hugo_Intel
Hello Ayun
We have received your request to close this thread so we will no longer monitor it. If you happen to still need assistance or if you have any other questions, feel free to open a new topic.
Hugo O.
Steve331
I am having the same issue. The driver defiantly gets rolled back and I have a big performance hit when gaming until I reinstall the correct driver.
This has Happened Three times in five months
CPU Intel 13600K
GPU: sparkle A770 16GB
MoBo: Gigabyte Z790 X AX
Ayun
Hi Steve,
after my original post I realized that the driver I was referring to is an older iGPU driver. For me the issue started after Intel changed the packaging of their GPU drivers. So it does seem as if Windows can't handle this packaging properly with my/our setup. Even setting all device updates to manual did not do the trick for me. For some reason Windows keeps "updating" to the older version regardless.
For me there are two solutions...
...if you don't use your iGPU in productive workloads, deactivate the iGPU in Bios. It is the solution that I am currently using and I had no issues since then.
...if you utilize the iGPU, you can use the Device Manager to manually set the driver for the iGPU under Display adaptors. Do this after the rollback happened, while not deinstalling the older one. For every new driver update it would be rinse and repeat. Please note that I do not know if this solution will cause any performance issues for Windows or your workloads.
I hope this helps,
all the best
Ayun
