Intel® Arc™ Discrete Graphics
3686 Discussions
Arc Control Panel - Missing Information
McNorris316
I have a Acer Predator Biforst Arc a770 16gb, running on latest drivers (4502)
When i go into Settings/System information i have the following fields showing as blank/incorrect:
Hardware/General Info
- PCI Gen Version - shows as "-"
- Storage - shows as "-MB"
Hardware/GPU Info
- GT Frequency - shows as "0.00 GHz"
- GT Memory Frequency - shows as "0 MB"
- Max Supported Devices - shows as "-"
- Xe -Cores - Shows as "-"
Software/Intel Software
- XeSDK - shows as "-"
- IDSA Version - shows as "-"
- Endurance Gaming Version - shows as "-"
Capabilities
- Shader Model - shows as 5.1, Direct X caps Viewer has shader listed as 6.5
GPU-Z shows this is running at PCIex16 4.0
I have reinstalled drivers and ARC control and still having same issue.
Jose_Intel
Hello @McNorris316
Thank you for posting on the Intel️® communities.
I am sorry to hear that you have problems with Intel® Arc™ A770 Graphics, and I’ll be more than happy to help you.
Please answer the following:
·      Was it showing the right information before?
·      Have you made a software change recently?
Please run the Display Driver Uninstaller (DDU), you will find the instructions there.
Then, install the driver again: Intel® Arc™ & Iris® Xe Graphics - WHQL - Windows*
Also, in order to have more information about your system, please download, install and run Intel® System Support Utility for Windows. Make sure you check “Everything” before you scan, then save the report and attach it to your response.
Jose B.
Jose_Intel
Hello McNorris316
We hope you are doing fine.
Jose B.
Remlin379
I have the same issue, the information was never there, already reinstalled it twice with DDU
Jose_Intel
Hello Remlin379.
Please submit a new question on the Graphics community forums, and provide a detailed explanation of the situation to have a more personalized troubleshooting step for your issue. If you'd like, you can try my suggestions from this thread.
Jose B.
Jose_Intel
Hello McNorris316
We hope you are having a nice day.
We have not heard back from you. So, we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jose B.
