Is anyone aware when the B50 linux support will be available? Following existing guides leads to nothing but issues. i.e.:
root@red:~# uname -a
Linux red 6.14.0-33-generic #33-Ubuntu SMP PREEMPT_DYNAMIC Wed Sep 17 23:22:02 UTC 2025 x86_64 x86_64 x86_64 GNU/Linux
root@red:~# sycl-ls
Bus error (core dumped)
root@red:~# cat /etc/lsb-release
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=25.04
DISTRIB_CODENAME=plucky
DISTRIB_DESCRIPTION="Ubuntu 25.04"
The GPU isn't detected in any of the llm tools either.
Hello ypk,
Thank you for reaching out regarding the B50 Linux support issues you're experiencing on Ubuntu 25.04.
To better assist you with this matter, could you please provide some additional information about your intended use case:
What is the primary purpose for your B50 setup?
Are you planning to use it for gaming?
Machine learning/AI development?
General computing tasks?
Professional workloads?
Dean R.
Hi Dean,
I'm primarily looking at running LLMs. VLLM with XPU doesn't seem to do the trick. I tried all the flavors of installing it, even changed the OS between LTS Ubuntu, latest Ubuntu and Debian Trixie.
Hello ypk,
Thank you for clarifying that you're primarily looking to run LLMs with VLLM using XPU support. I understand you've tried multiple installation approaches and even tested different operating systems (LTS Ubuntu, latest Ubuntu, and Debian Trixie) without success.
To better assist you with the B50 Linux support for LLM workloads, I need some additional information:
- System Configuration:
- Could you provide an Intel SSU report or system specifications including:
- Complete system hardware details
- Current Intel graphics driver version (if any installed)
- BIOS version and settings
This information will help me better understand your setup and provide more targeted guidance for LLM workloads on the B50.
Dean R.
System info (has everything you need):
red
description: Desktop Computer
product: B550M DS3H (Default string)
vendor: Gigabyte Technology Co., Ltd.
version: Default string
serial: [REDACTED]
width: 64 bits
capabilities: smbios-3.3.0 dmi-3.3.0 smp vsyscall32
configuration: boot=normal chassis=desktop family=B550 MB sku=Default string uuid=[REDACTED]
*-core
description: Motherboard
product: B550M DS3H
physical id: 0
version: x.x
serial: [REDACTED]
slot: Default string
*-firmware
description: BIOS
vendor: American Megatrends International, LLC.
physical id: 0
version: F13
date: 07/08/2021
capacity: 32MiB
capabilities: pci upgrade shadowing cdboot bootselect socketedrom edd int13floppynec int13floppytoshiba int13floppy360 int13floppy1200 int13floppy720 int13floppy2880 int5printscreen int14serial int17printer int10video acpi usb biosbootspecification uefi
*-memory
description: System Memory
physical id: b
slot: System board or motherboard
*-bank:0
description: DIMM DDR4 Synchronous Unbuffered (Unregistered) 3200 MHz (0.3 ns)
product: F4-3200C16-32GTZR
vendor: Unknown
physical id: 0
serial: [REDACTED]
slot: DIMM 0
width: 64 bits
clock: 3200MHz (0.3ns)
*-bank:1
same as above
*-bank:2
same as above
*-bank:3
same as above
*-cache:0
description: L1 cache
physical id: e
slot: L1 - Cache
*-cache:1
description: L2 cache
*-cache:2
description: L3 cache
*-cpu
description: CPU
product: AMD Ryzen 9 3900X 12-Core Processor
vendor: Advanced Micro Devices [AMD]
serial: [REDACTED]
slot: AM4
capacity: 4673MHz
configuration: cores=12 enabledcores=12 microcode=141561908 threads=24
*-pci:0
description: Host bridge
product: Starship/Matisse Root Complex
vendor: Advanced Micro Devices, Inc. [AMD]
*-nvme
description: NVMe device
product: Sabrent Rocket 4.0 1TB
vendor: Phison Electronics Corporation
logical name: /dev/nvme0
serial: [REDACTED]
configuration: nqn=[REDACTED]
*-namespace:2
logical name: /dev/nvme0n1
configuration: guid=[REDACTED] wwid=[REDACTED]
*-volume:0
logical name: /dev/nvme0n1p1
serial: [REDACTED]
*-volume:1
logical name: /dev/nvme0n1p2
serial: [REDACTED]
*-volume:2
logical name: /dev/nvme0n1p3
serial: [REDACTED]
*-network:0 DISABLED
product: NetXtreme II BCM57810 10 Gigabit Ethernet
vendor: Broadcom Inc. and subsidiaries
logical name: enp4s0f0
serial: [REDACTED-MAC]
*-network:1
logical name: enp4s0f1
ip=[REDACTED-IP]
*-nvme
logical name: /dev/nvme1
serial: [REDACTED]
*-namespace:2
logical name: /dev/nvme1n1
*-volume:0
logical name: /dev/nvme1n1p1
serial: [REDACTED]
*-volume:1
logical name: /dev/nvme1n1p2
serial: [REDACTED]
*-volume:2
logical name: /dev/nvme1n1p3
serial: [REDACTED]
*-volume:3
logical name: /dev/nvme1n1p4
serial: [REDACTED]
*-network
product: RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet Controller
vendor: Realtek Semiconductor Co., Ltd.
logical name: enp6s0
ip=[REDACTED-IP]
*-display
product: Battlemage G21 [Intel Graphics]
vendor: Intel Corporation
logical name: /dev/fb0
configuration: resolution=3840,2160
*-multimedia
product: Intel Corporation Audio Controller
logical name: card1
*-usb
product: USB Receiver
vendor: Logitech
product: Logitech K400 Plus
logical name: /dev/input/event2
*-multimedia
product: Starship/Matisse HD Audio Controller
logical name: card0
*-input:*
description: HD-Audio Generic [various inputs]
*-input:0
product: Power Button
*-input:1
SSU:
$ sudo ./ssu.sh
This product is not supported on this operating system.
Would you like to try to scan? (y/n)
yNo further output.
Currently under Ubuntu 25.04 (GNU/Linux 6.14.0-33-generic x86_64)
Hi ypk,
Thank you for providing the detailed system information. I can see you have the Intel Arc Pro B50 (Battlemage G21) installed in your AMD Ryzen 9 3900X system running Ubuntu 25.04, and you're experiencing issues with LLM workloads using VLLM with XPU support.
I understand you've tried multiple installation approaches across different Linux distributions (LTS Ubuntu, latest Ubuntu, and Debian Trixie) without success, and the Intel SSU tool is not supported on your current OS configuration.
I will be checking this further internally regarding B50 Linux support for LLM workloads and will get back to you once I have more information available.
Thank you for your patience as we investigate this Linux compatibility issue.
Dean R.
