Intel® Arc™ Discrete Graphics
3646 討論
Arc driver 32.0.101.8135 flagged as virus
Gil45
新手
1,195 檢視
My antivirus quarantied the latest software as Heur.BZC.Boxter.781.1D5964DD.
Also the powershell command was flagged as highly suspicious and blocked
"C:\Windows\System32\WindowsPowerShell\v1.0\powershell.exe" -NoProfile -WindowStyle Hidden -ExecutionPolicy Bypass -Command "$expected=[System.Numerics.BigInteger]::Parse('15828842848686148553215333582797196630597386042548628406363993409161138245193439'); $args = [Environment]::GetEnvironmentVariable('sfxcmd', 'Process'); $sum = [System.Numerics.BigInteger]::Zero; Get-ChildItem . -Recurse -File | ForEach-Object { $hash = Get-FileHash $_.FullName -Algorithm SHA256; $sum += [System.Numerics.BigInteger]::Parse('00' + $hash.Hash, [System.Globalization.NumberStyles]::HexNumber) }; if ($sum -eq $expected) {$proc = Start-Process Installer.exe -ArgumentList $args -Wait -PassThru; exit $proc.ExitCode} else { Add-Type -AssemblyName System.Windows.Forms; $msg = \"The installation cannot start because the file integrity check failed. The package appears to be corrupted or modified. Please download the driver and try again. If the problem persists, visit www.intel.com/support for assistance.\"; [System.Windows.Forms.MessageBox]::Show($msg,'Error',[System.Windows.Forms.MessageBoxButtons]::OK,[System.Windows.Forms.MessageBoxIcon]::Error) }"
0 積分
1 解決方案
KentRusselP_Intel
1,117 檢視
Hi Gil45,
I just wanted to follow up and check if you’ve had a chance to review the information I shared previously. Your feedback is important, and I’d appreciate it if you could share your thoughts at your earliest convenience.
If you have any questions or need further clarification, please don’t hesitate to reach out.
Kent Russel P.
在原始文章中檢視解決方案
5 回應
KentRusselP_Intel
1,180 檢視
Hi Gil45,
Thank you for reaching out to the Intel Community Forum. Rest assured, I’m here to assist you with your concern.
To better understand the issue and provide more accurate support, could you please share the following details:
  • How did you obtain the graphics driver? Was it downloaded from the Intel website or via the Intel Driver & Support Assistant?
  • What antivirus application are you using?
  • When did the issue first occur?
Additionally, please provide screenshots showing the flagged virus details from your antivirus software. In the meantime, we recommend refraining from updating the graphics driver until we’ve reviewed the information.
To help us gain a comprehensive understanding of your system, kindly run the Intel® System Support Utility (SSU). This tool will generate a text file containing your system information. You can follow the instructions provided in this guide: Help Guide for the Intel® System Support Utility. Once completed, please attach the generated file to your response. If you have any further questions or need additional assistance, feel free to reach out.
Kent Russel P.
Gil45
新手
1,097 檢視
And to answer your question: in both cases I used Intel Driver and Support Assistant. I use Bitdefender as antivirus software.
KentRusselP_Intel
1,118 檢視
Hi Gil45,
Kent Russel P.
Gil45
新手
1,098 檢視
Thank you for replying. I have tried with the driver released on the 7th of October and this one installs without any issues.
KentRusselP_Intel
1,031 檢視
Hi Gil45,
Thank you for your update. I'm glad to hear that you were able to install without any issues. I’ll go ahead and close this thread. Should you require further assistance or have additional questions, please feel free to submit a new request. Kindly note that this thread will no longer be monitored once closed.
Kent Russel P.
回覆
