Intel® Arc™ Discrete Graphics
3482 Discussions
B580 on Linux: Cyberpunk 2077 shader and RT issues, Halo Infinite crashes.
MomoB580
Seems like most games work this time, just have two problem games. Cyberpunk 2077 has shader issues with z-fighting, incorrect depth, sunlight leaking and fog being bright white, and Halo Infinite doesn't start at all. It also assumes the GPU we have has less than 4GB of VRAM.
I've included some screenshots to show the two problems and my system specs. I should note that during trying to trouble this I upgraded the kernel and version of mesa from the defaults to bleeding edge builds (using the "Mainline" kernel switching tool and the "oibaf" PPA for mesa) from the mainline linux repository and the mesa 25 development repository. This made no difference.
I should note that other games such as Deadlock (on both dx11 and Vulkan), Halo: The Master Chief Collection and Armored Core VI work fine.
EDIT: Forgot I can run steam in verbose mode. It does give me a vulkan error when Halo Infinite crashes on loading.
"Assertion failed: alignment > 0 && (alignment & (alignment - 1)) == 0, file ../src-vkd3d-proton/include/private/vkd3d_common.h, line 57"
Something is failing in VKD3D when proton calls it.
Linux 6.13.0-061300rc1-generic
Mesa 25.0~git2412240600.dff14d~oibaf~o
Screenshot From 2024-12-25 01-16-05.pngScreenshot From 2024-12-25 01-16-43.pngScreenshot From 2024-12-25 01-17-04.pngScreenshot From 2024-12-25 01-21-42.png
ACarmona_Intel
Hello MomoB580,
I have tried the games that are having an issue in our lab using Windows 11, and I do not encounter any issue; it seems that that issue may be isolated to Linux.
To further investigate the issue, kindly provide the following information.
1. Please generate an SSU report to help me further analyse your system specifications and configuration. To generate the SSU report, please refer to the article: Intel® System Support Utility for the Linux* Operating System. Please send us the generated SSU.txt file.
2. Kindly share a video with us showing the issue in the game. If you can also share the game settings, that would be better.
Carmona A.
ACarmona_Intel
Hello MomoB580,
I am checking in with you to see if you already have the information that I requested in order for me to continue to further investigate our issue.
Thank you!
Carmona A.
ACarmona_Intel
Hello MomoB580,
This is only a quick follow-up; I just wanted to check in with you, as I haven't received any feedback from you.
Carmona A.
ACarmona_Intel
Hello MomoB580,
I hope you are doing well.
Since I have not heard back from you, I will now be closing our case.
If, in case you are just busy and still needed assistance, please submit a new question on our community: https://community.intel.com/, as this thread will no longer be monitored.
Thank you.
Carmona A.
