Intel® ARC™ Graphics
3370 Discussions
Battlemage support for virtualization
pseudomotivated
With the release of B series Arc GPUs recently I was considering one for my rig, for that I am wondering about whether they support virtualization. And in that case what technology etc, as I found nothing on Battlemage specifically here.
Thank you for your time.
JeanetteC_Intel
Hello pseudomotivated,
I'll check on this query and I will post an update once it's available.
JeanetteC.
Bandit8623
New Contributor III
I am Also curious. I tried to passthrough an a380 but no support and doesn't work. Would be good if Battlemage supported sriov or gpu -p
Flolingo
I also tried it with an a770 in proxmox. It worked but schutting down the vm crashes the host. I hope Battlemage will support this and a driver update for the alchemist gpus would also be nice. Nvidia and Amd both support it so why not intel?
Bandit8623
New Contributor III
@Flolingo
yeah i had luck with Gpu-p but it would not pass media engine through properly.  i could see the gpu but no luck with transcoding.
also on my newer system if i enable sr-iov i cant get my system to boot with the A380 installed into bare metal windows.
JeanetteC_Intel
Hello Bandit8623 and Flolingo,
I understand that you are facing the same situation, however, I kindly request that you create a new thread for your case. This will allow us to focus on your specific problem and provide you with better assistance.
Sincerely,
JeanetteC.
Bandit8623
New Contributor III
Jean you haven't answered the ops question. Our question is the same. Thanks.
JeanetteC_Intel
Good day.
As confirmed in article https://www.intel.com/content/www/us/en/support/articles/000093216/graphics/processor-graphics.html the Intel® Arc™ B-Series discrete graphics do not support virtualization technologies.
Intel won't discuss the reasons behind this situation.
I hope this answers your question.
JeanetteC.
Bandit8623
New Contributor III
Looks like people who want support need to buy AMD or Nvidia GPUs.. sad Intel.. sad
Flolingo
Yes, very sad. Why doesn't intel give any reason? Will they get support in the future? I don't know much about this topic but I assume it's just a driver thing, because without the intel driver installed in the vm, it works fine. If that is the case then intel has done very weak.
Bandit8623
New Contributor III
Yes definitely a driver thing. Nvidia learned their lesson on transcoding limitations a few years back. Guess Intel is still in baby stages. When you open your hardware up you sell more hardware.
Heloc
Kinda a bummer, a hardware limitation. Or just a "software isn't implemented" case?
Bandit8623
New Contributor III
@Heloc its a driver limitation.  you can passthrough the entire card with some hypervisors,  but sr-iov isnt not supported because the driver has to support in that case.  PCI passthrough has been available since at least February 2015
Heloc
So, SR-IOV is implementable for Arc cards in the Xe driver, neat.
What I don't understand is why they are implementing it on iGPUs but not consumer dGPUs, there isn't a whole lot of compute resources to be shared with iGPUs. And it's not like they haven't done SR-IOV on dGPUs (Intel® Data Center GPU Flex Series discrete graphics family).
Bandit8623
New Contributor III
@Heloc  they have a pro line they are selling that has the option they want data centers to buy those not the consumer ones.  They could support sr-iov if they wanted too.
