Intel® ARC™ Graphics
3423 Discussions
Both the game and Discord are experiencing performance lag when streaming a game to Discord?
DuskyRick
I'm trying to stream Fortnite or Lost Judgment on Discord to my friends, but both my Discord and the game, even the whole system, are lagging, resulting in a lot of stuttering as well. I think it could be because Discord is using the Opus codec, and I do use 1080p at 30fps. Has anyone found a fix for this?
1. **Graphics Driver Details**:
- Intel Graphics Driver Version: 32.0.101.6262
2. **Applications Used**:
- Discord for voice chat and streaming.
- Fortnite (Epic Games version)
- Lost Judgement (from Steam version)
3. **System Information**:
- Processor: Ryzen 7 5700X
- Motherboard: MSI B550M Pro VDH Wifi
- RAM Amount: 32GB (2x16GB)
- Operating System: Microsoft Windows Version 23H2 (OS Build 22631.4751)
- PSU: Cooler Master MWE 750W V3 Bronze
4. **Reproduction Steps**:
- Open Discord and ensure it is up-to-date.
- Launch either Fortnite or Lost Judgement through their respective platforms.
- Join a voice channel in Discord to stream the game with friends.
- Experience lag during gameplay.
RandyT_Intel
Hi DuskyRick,
To help resolve this, I recommend turning off GPU acceleration in the Discord application. Below are the steps to do so, along with an explanation of the effects and reasons for this change.
Step-by-Step Guide to Turn Off GPU Acceleration in Discord
  • Open Discord:
    • Launch the Discord application on your computer.
  • Access User Settings:
    • Click on the gear icon located at the bottom left corner of the Discord window, next to your username. This will open the User Settings menu.
  • Navigate to Advanced Settings:
    • In the User Settings menu, scroll down and click on the "Advanced" option under the "App Settings" section.
  • Disable Hardware Acceleration:
    • In the Advanced settings, you will see an option labeled "Hardware Acceleration." Toggle the switch to the off position to disable GPU acceleration.
  • Restart Discord:
    • After disabling Hardware Acceleration, you will need to restart the Discord application for the changes to take effect. Click "Okay" when prompted to restart.
Disabling GPU acceleration may result in a slight decrease in performance, particularly in rendering animations and transitions within the Discord application. This is because the application will rely more on the CPU rather than the GPU for these tasks. By turning off GPU acceleration, the GPU will have more available resources for other tasks, which can be beneficial if you are running multiple GPU-intensive applications simultaneously. Additionally, GPU acceleration can sometimes cause instability in applications, especially if there are compatibility issues with the graphics driver or if the GPU is under heavy load. Disabling this feature can help improve the stability of Discord, reducing the likelihood of crashes while streaming. lastly, If Discord is crashing while streaming, it could be due to conflicts between the GPU acceleration and other processes or applications running on your system. Disabling GPU acceleration is a common troubleshooting step to isolate and resolve such issues.
If the issue persists, please let us know so we can further investigate other potential causes.
Randy T.
RandyT_Intel
Hi DuskyRick,
I want to know more about the issue you are experiencing. Could you please provide answer to my questions?
  1. What is the exact make and model of your GPU?
  2. Are you using the desktop application or a web browser to launch Discord?
  3. Are the issues only seen on Discord, or do you observe similar issues in other applications?
  4. If the issue is only happening with the desktop application, have you tried reaching out to Discord technical support?
  5. When did the issue first occur? Has this been happening before?
  6. Have there been any recent software or hardware changes made to your system?
  7. How did you perform the last update? Did you use a device manager-clean installation or Display Driver Uninstaller (DDU) before updating to the latest graphics driver?
Providing this information will help me diagnose the system more accurately and check for available solutions. Thank you for your cooperation, and I look forward to your response.
Randy T.
DuskyRick
1. My GPU is an Intel Arc B580 12GB Gunnir Index.
2. I'm using the desktop application of Discord.
3. I just noticed that when I'm using anything that is recording, like OBS Studio, my game lags as well.
4. I have not yet asked Discord because the streaming worked fine on my laptop, which has an NVIDIA GTX 1650 TI mobile and Ryzen 5 4600H.
5. It first occurred when I tried streaming yesterday on Discord.
6. Nothing that I know so far.
7. I haven't tried using DDU, but I only used it when cleaning NVIDIA and AMD drivers back when I installed the Intel Arc drivers after I built my computer. After that, I updated my Intel Arc drivers through Intel Graphics Software.
RandyT_Intel
Hi DuskyRick,
You may try running Discord when not in admin mode. Intel is currently investigating this issue.  Notably, this issue does not arise when using Discord's web version in a browser; it is isolated to the desktop application. If the issue persists, kindly try to contact Discord's technical support because the issue is only happening when using the desktop application
Randy T.
DuskyRick
I tried streaming in the browser, but the issue persists. Thanks for your help, and good luck with the investigation.
DuskyRick
Hello again!
There seems to be an issue with using the Lossless Scaling application as well, as stated in this Reddit post.
Someone even left a comment on that post about capturing frames.
I was wondering if this might be connected to the streaming problem on Discord. They mentioned that the Intel Alchemist cards don’t have this issue, but the B580 does.
I hope this new information helps with looking into the issue. Thank you, and best of luck!
stevejames
Were you able to find the solution to this in the post's comments section?
DuskyRick
No unfortunately, some people have the same problem as well.
RandyT_Intel
Hi DuskyRick,
I don't have an answer at this moment, but I'll investigate it and get back to you as soon as possible. I'm going to look into the issue further.
Randy T.
RandyT_Intel
Hi DuskyRick,
  • Open Discord:
  • Restart Discord:
Randy T.
DuskyRick
Hi there!
I did some testing with Fortnite, and I noticed that there was some stuttering at first, but it cleared up after a few seconds of streaming on Discord. I plan to try out some other game modes and different games to see how it goes. Thanks again for your support.
AsterCrash
Hi, good morning
I'm having the same streaming issue even though I disabled hardware acceleration on Discord and the option to share my screen.
RandyT_Intel
Hi DuskyRick,
I'm glad to hear that my recommendation has had a positive effect on your system and that the issue with Discord crashing while streaming has been addressed. I will now proceed with closing this thread.
If you need further assistance, especially regarding any game-related issues, please feel free to submit a new ticket. As this case will no longer be monitored, do not hesitate to contact us again. We are here to help you.
Randy T.
Tellious
Hi another solution is unchecking "Show My Screen Share" and it works across all resolutions and framerate options. No need to disable hardware acceleration, changing codecs or w/e.
(You may need to do it twice if it doesn't work the first time)
Right click your Screen Share previewRight click your Screen Share preview
samuel02
If both your game and Discord are lagging while streaming, it usually means your system is under heavy load or resources aren’t being allocated properly. Here are the main causes and fixes:
  • Hardware limitations – Streaming plus running a game is resource-intensive. Check your CPU, GPU, and RAM usage in Task Manager. If they’re maxing out, lowering game graphics or stream quality can help.
  • Discord settings – Go to User Settings > Voice & Video and reduce stream resolution (e.g., 720p) or frame rate (30fps instead of 60fps). Also, disable hardware acceleration in Discord to see if performance improves.
  • Game settings – Lower in-game graphics, resolution, or enable V-Sync to reduce GPU strain.
  • Background processes – Close unnecessary apps or browser tabs that consume CPU/GPU/RAM.
  • Drivers and updates – Make sure your graphics drivers, Windows, and Discord are up to date.
  • Internet connection – A slow or unstable network can also cause lag. Run a speed test and try using a wired connection instead of Wi-Fi.
If the lag persists, try running Discord as administrator or switching to Windowed/Borderless Windowed mode in the game, as these sometimes smooth out performance.
ArthurFinch
That is definitely frustrating; trying to stream high-quality games like Fortnite and Lost Judgment shouldn't cause your whole system to stutter! Your issue is most likely a classic resource conflict, specifically due to Discord's stream competing with your demanding games for GPU and CPU power. To fix this, first, disable Hardware Acceleration in Discord's Advanced Settings (as this often causes system conflicts), and second, check your in-game settings to cap the frame rate a little lower than 1080p/30fps to free up resources. If the lag persists, try lowering Discord's stream quality to 720p at 30fps.
AsterCrash
Hi good evening the performance drop is still the same and my hardware acceleration for discord is always off.
ArthurFinch
Fantastic observation; identifying both the game and Discord lagging simultaneously is key! Widespread performance hit strongly suggests your PC's resources, particularly GPU or network bandwidth, are severely overloaded. Try lowering the streaming resolution and framerate settings within Discord's settings immediately. Also, ensure the game runs with less intensive graphics settings to relieve pressure on the system.
AsterCrash
Yes, I tested it at different resolutions and frame rates and the impact is the same.
