Intel® Arc™ Discrete Graphics
3590 Discussions
CTD, Arc B570, The Division 2, Driver Version: 32.0.101.7026 and some older drivers
miyuri
Unreproducible crash. Mission Occurs most frequently at Bank Headquarters.
However, this issue does not occur in 32.0.101.6913
If I were only playing this video game, I would continue using 32.0.101.6913 and there would be no problem, but that is not the case, so I want the problem fixed.
This video game uses a program called Easy Anti-Cheat, which prevents crash dumps from being generated. This makes troubleshooting the issue more difficult.
driver.
Intel Graphics Driver 32.0.101.7026
name of the game and where to obtain it.
Tom Clancy’s The Division 2
UBI SOFT STORE https://store.ubisoft.com/
Processor make and model.
Intel
Core i5-10400
Motherboard make and model.
ASRock
H470 Steel Legend
Amount of memory (RAM).
32 GB
Operating System version/build number.
Microsoft Windows [Version 10.0.26100.4946]
Power Supply make and model.
Antec
NeoECO Gold NE650G
the steps to reproduce the issue.
No reproducibility.
game settings.
Graphics:
Graphics Quality - High
Video:
Windowed Mode - Fullscreen
Resolution - 1920 x 1080
Refresh Rate - 74.97 Hz
Enable Reduced Latency - No
Enable DX12 Renderer - Yes
other.
The entire system memory and video game files are fine.
ASPM enabled, PCI Express Link State Power Management Maximum power savings.
Labels (3)
miyuri
I doubt it can resolve performance issues in any video game using D3D11 or earlier, or OpenGL.
More importantly, when using D3D12, I want you to fix the issue where it worked fine with version 32.0.101.6913 but started crashing with 32.0.101.6972, and continues to crash even with the latest driver.
JedG_Intel
Hello miyuri,
We attempted to replicate the issue using both the game settings you previously provided and the configurations we recommended. However, we were unable to observe any stuttering during our testing.
Furthermore, it appears that this issue is not isolated to Arc Graphics as other users are reporting the similar crashing issue with other GPUs, could be caused by the game itself. We suggest that you contact Ubisoft for further assistance.
You may also check the links below:
https://www.reddit.com/r/thedivision/comments/1kmoxeb/game_keeps_crashing_please_help_me/
https://www.reddit.com/r/thedivision/comments/1kx58hn/2_years_later_td2_still_crashing/
https://steamcommunity.com/app/2221490/discussions/0/596285020004539634/
https://steamcommunity.com/app/2221490/discussions/0/596280581879327553/
With this in mind, I will now close this inquiry. If you have other questions or concerns, please submit a new question as this thread will no longer be monitored.
Best regards
Jed G.
miyuri
Jed G, perhaps you don't understand the situation.
Before using the Arc B570, I was using an AMD Radeon RX 580 and Vega 56, and I was able to play without any chronic crashes.So I don't think it's right to contact Ubisoft about this issue.
These are probably due to NVIDIA GeForce having chronic issues with D3D12.
No such crashes have occurred with AMD Radeon or Intel Arc BMG (Driver Version: 32.0.101.6913).
As explained at https://trello.com/c/Mksh8bzA/51-stability-pc-crashes-can-occur-when-interacting-and-trying-to-claim-the-final-loot-cache-in-the-countdown-mode this is a bug in the game program that causes it to rarely crash when opening a crate in the mission Countdown.
When I was using Radeon, I encountered this bug when opening a crate near the center of the cooling tower.
I want to report other issues without having to replace the driver each time.
heliconzero
This is not a great response. I also have this issue and to just close it because you're not able to reproduce it on your side is unfortunate.
Crashing is completely random - sometimes after 2 minutes, sometimes after 30. Happens in various parts of the map, but most frequently after zoning. It's always accompanied by microstutters and lag.
driver.
Intel Graphics Driver 32.0.101.7029 and 32.0.101.7026
This version obtained via Steam
AMD
Ryzen 7 3700X
MSI
MPG B550 Gaming Edge Wifi
32 GB
Microsoft Windows 10 21H2 [Build 19044.6332]
Seagate
Prime TX-700
No reproducibility.
game settings.
Graphics:
Graphics Quality - Ultra
Video:
Refresh Rate - 60.000 Hz
Enable Reduced Latency - Yes
other.
Have reinstalled, deleted shader caches etc
Resizable bar enabled
the 101.6987 version is the last version of the driver that worked without crashing for me (although I do get occasional framerate drops and stutters).
the 101.6651 version of the drivers works incredibly well and has the smoothest framerates of all the versions I've tested.
- So at this point you have the same issue reported for intel CPUS, AMD cpus, B570 and A770.
Will you start taking it seriously now?
AmniClave
 while all your hardware is stable confirms this. The anti-cheat software making crash dumps impossible is what turns a normal bug into a frustrating, "black box" problem. Your best course of action is to submit a detailed bug report directly to Intel and wait for a fix in a future driver release. You've already done all the user-side troubleshooting you can.
miyuri
Intel customer support seems like a bot.
I don't think that is human.
miyuri
Driver Version: 32.0.101.8247
No glitches were encountered during a total of about 9 hours of gameplay.
This version will likely continue to function without issues.
The previous version, 32.0.101.8136, crashed in less than 30 minutes.
Microsoft Windows [Version 10.0.26200.6901]
Game program updated on 2025-10-21 (timestamp 2025-10-15T01:51:25)
