Intel® Arc™ Discrete Graphics
3527 Discussions
Cant install/uninstall iris driver
JBurlison
The installer/uninstaller crashes when launching. Windows event viewer has this error log:
Description: A .NET application failed.
Application: Installer.exe
Path: C:\Users\JBurl\AppData\Local\Temp\Intel\Installer\Installer.exe
Message: A JSON parsing exception occurred in [C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\8.0.14\Microsoft.WindowsDesktop.App.runtimeconfig.json], offset 0 (line 1, column 1): The document is empty.
Invalid framework config.json [C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\8.0.14\Microsoft.WindowsDesktop.App.runtimeconfig.json]
As a side note that probably caused this, the driver was doing an update and the installer crashed during the update:
Application: IntelGraphicsSoftware.exe
Path: C:\Program Files\Intel\Intel Graphics Software\IntelGraphicsSoftware.exe
ArchieD_Intel
Hi JBurlison,
  • When did the issue start? Was it after a specific update?
  • What are the troubleshooting steps that you tried so far?
  • Have you used DDU to completely remove all residual drivers and installed a new one?
  • Can you please provide a video of the issue when installing the driver?
Additionally, to gain a comprehensive understanding of your system, please use the System Support Utility (SSU). This tool will generate a text file compiling all your system information. You can follow the instructions at this link and send the text file here. Help Guide for the Intel® System Support Utility.
Archie D.
ArchieD_Intel
Hi JBurlison,
Archie D.
ArchieD_Intel
Hi JBurlison,
Archie D.
