- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Game crashes with the following error: Fatal D3D error (25, DXGI_ERROR_DEVICE_HUNG, 0x887a0006)
The driver is version 32.0.101.6632. I updated from a previous version after a crash earlier tonight, then experienced another crash on version 6632 as well. The specific card I'm using is the B650 AORUS Elite AX ICE.
Game is Street Fighter 6 on Steam, most current version installed.
Intel SSU report is attached.
This has been happening consistently since I began using the card so the steps to reproduce are not clear to me. The only thing I can identify is that it does not crash in menus or while navigating the map in World Tour mode, only during an active match. In this specific instance I played through 5 stages of the Arcade mode with no issues. After losing the final match I selected Continue and the game crashed immediately.
Performance appears fine otherwise. 60 FPS is consistent in matches. I notice some slowdown on animations both before the match begins and during a super art, but nothing affecting gameplay. Have not played online PVP yet, this is all vs. CPU. Graphics settings are fairly high.
I've also attached the Capcom crash report from Steam.
링크가 복사됨
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi sleepingtoads,
I appreciate you getting in touch with us and spending the time to work on the issue you brought up.
For us to determine the best solution to your concern, could you please provide the needed details listed below:
- May I know if the game is working fine before? if yes, what is the previous graphics driver version your using?
- Did you perform clean installation of your Graphics Driver before installing B580?
- What Graphics Card do you previously have?
Once we have this information, we will be able to proceed with the next course of action and work towards resolving the issue you are facing.
Earl E.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I did not perform a clean installation. I see there has been another driver update in the last few days, should I attempt to clean install version 6647?
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hello sleepingtoads,
Thank you for sharing this information with us.
Sure thing! Try performing clean installation then install the latest Graphics Driver update (version: 32.0.101.6647) and check if the issue will still persist.
- Latest GPU: Intel® Arc™ & Iris® Xe Graphics - Windows*
- Clean installation: How to Use the Display Driver Uninstaller (DDU) to Uninstall an...
Earl E.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi sleepingtoads,
I just wanted to check ion you if had the chance to try performing clean installation and updating your drivers to the latest version. Please let me know at your earliest convenience so that I can determine the best course of action to resolve this matter.
Earl E.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Thank you for sharing the update with us.
I'm happy to hear that the crashes have been resolved on the latest driver update!
Since the issue is now resolved, I will no longer monitor this thread.
You can continue to monitor the performance of your system on the new driver, if you need further assistance, please submit a new question as this thread will no longer be monitored.
Earl E.
