Intel® Arc™ Discrete Graphics
3669 Discussions
Create2Dtexture Failed Error(Fatal)
Rahat_noob
While playing Call Of Duty modern warfare Remastered , Getting create2Drexure fail error..
I have tried with Shader Preload option off. But the error was still there..
Good to mention that I am using ARC A750 and also the latest driver for now(6253)..
Mike_Intel
Hello Rahat_noob,
  1. When did you purchase your ARC A750?
  2. Are you using an Intel brand ARC A750?
  3. Was it working fine before?
  4. How did you update the Graphics driver and kindly provide the complete driver version installed?
Michael L.
Rahat_noob
Okay I am giving all the information.
1. Around 4 month earlier I bought my ARC A750
2. Yes, it is intel ARC A750 founders edition
3. In others games it just works fine.. Only when I try to play COD modern warfare then the issue come up.
4. Usually I update using Display Driver Uninstaller(DDU) and then install the driver. But last time I updated through intel graphics software. I am currently using
-> intel graphics software version - 24.48.47.5
-> intel ARC graphics driver version - 32.0.101.6332_101.6253
Mike_Intel
Hello Rahat_noob,
Thank you for the update.
Upon checking, the latest Graphics driver that we have is 32.0.101.101.6256.
You can update the driver again to the latest using DDU, you can download the driver in the link below:
https://www.intel.com/content/www/us/en/download/785597/intel-arc-iris-xe-graphics-windows.html
Michael L.
Mike_Intel
Hello Rahat_noob,
Michael L.
Mike_Intel
Hello Rahat_noob,
I am sending another follow up if you tried our recommendations.
Michael L.
