Intel® Arc™ Discrete Graphics
3664 Discussions
DX12 Performance MW3
Radbod
With all new Drivers the Frames drop. With the newest i get Framedrops in Zombies Modes under 60 fps! In most cases CPU is used 80-100%
Older drivers doesnt perform that bad.
I put SUS specs later
DeancR_Intel
Hi Radbod,
Thank you for posting in the Community!
Apologies for the delay on my response. Please make sure you provide the following basic information when reporting a bug:
  1. What is the graphics driver you are using?
  • Confirm you are using the latest WHQL graphics driver available (let us know the exact driver version you are using).
  • A clean driver installation using DDU in safe mode is recommended. Follow this link for instructions.
  • You could also test using the latest Beta driver. Our Beta drivers go through all Intel quality assurance processes and are safe to use for evaluation.
  1. Tell us the name of the game or application and where to obtain it (Steam, Epic, etc.)
  2. Provide us with the Intel SSU report from your system.
  • If you do not wish to submit the SSU report then at least provide us with the following information about your system:
    • Processor make and model.
      • Power Supply make and model.
    • Motherboard make and model.
    • Amount of memory (RAM).
    • Operating System version/build number.
  1. Tell us the steps to reproduce the issue (this is very important!).
  2. For graphics corruption (per example artifacts, textures corruption or lighting glitches) please use Intel Arc Control to capture screenshots or a video showing the bug.
Dean R.
DeancR_Intel
Hi Radbod,
Dean R.
DeancR_Intel
Hi Radbod,
Since I haven't received a response from you, I will be closing this inquiry. If you need further assistance, please submit a new question, as this thread will no longer be monitored.
Dean R.
