Intel® Arc™ Discrete Graphics
3557 Discussions
Davinci Resolve crashes CONSISTENTLY - Arc B580
Danyyy3l
I think it is already pretty known that Davinci is very unstable with the ARC B580, as I've seen quite a few posts online about it, but I don't think anyone mentioned this consistent way of how you can crash it.
Not sure how actually useful this information is, but one way I found to crash the application consistently, is by using the "Versions" buttons for preset effects on the edit page. This is especially annoying for me because I use this feature in pretty much every one of my effect presets, therefore making me have to stop using it because I crash very often with it.
So I just made this "Slides" macro that I will share here, so you can try to replicate it if you want. It's just a simple slide-in effect. and Im using the "versions" feature to store 4 variations of this effect preset (slide up/down/left/right).
I find that when I apply this to a clip, and try to switch to one of these versions, very often davinci resolve freezes RIGHT AWAY as soon as I click on one of them, and the only thing I can do is force-close it and restart it.
Sometimes it doesn't crash right away from a single click (even tho it is pretty often the case for me), but If you repeatedly click and switch between these versions very fast, it will ALWAYS crash.
NOTE: Inside the fusion-page of davinci resolve, the "versions" DON'T CRASH the application, and they work completely fine, even If I click them repeatedly very fast.
(To quickly test this, click on the magic wand button on the effect (I outlined it with GREEN on the picture), and there you will have that same effect but in the fusion-page)
https://drive.google.com/file/d/1qejkG2IBFjZIaNN0zcB_PiiXx5Or7Kuh/view?usp=drive_link
Here is the link to that "Slides" effect preset.
(Place it inside "C:\Users\***USERNAME***\AppData\Roaming\Blackmagic Design\DaVinci Resolve\Support\Fusion\Templates\Edit\Effects")
VonM_Intel
Hi Danyyy3l,
Thank you for taking the time to share such a detailed report and for even including a reproducible example. You’re absolutely right that DaVinci Resolve has previously exhibited instability when used with the Intel® Arc™ B580 graphics, particularly around certain editing functions like the “Versions” button on effect presets. We’ve seen similar feedback and understand how disruptive that can be to your workflow.
The good news is that this specific issue has been addressed as of graphics driver version 32.0.101.6881. We highly recommend installing this version or any newer release, as it includes stability improvements specifically targeting DaVinci Resolve and related crash scenarios.
You can download the latest Intel Graphics Driver here: Intel Download Center – Arc Graphics Driver
After updating, please feel free to test the effect preset again. If you continue to experience crashes or instability, don’t hesitate to share the behavior, and we’ll be more than happy to dig deeper.
Von M.
Danyyy3l
Unfortunately I still have a bunch of stability issues regardless of the driver version.
I've been through almost every driver version, and all of them have stability issues with davinci resolve.
https://community.intel.com/t5/Intel-ARC-Graphics/B580-Stability-Issues-with-DaVinci-Resolve-Missing-OpenGL-Entry/m-p/1695427
This post by a user explains how there are errors with davinci resolve that persist across all driver versions (I checked on my system aswell and I also get these errors in my logs of davinci resolve)
I hope this gets resolved soon
VonM_Intel
Hello Danyyy3l,
Thanks for sharing that. The fact that you're seeing the same errors mirrored in both your experience and the community post really helps paint a clearer picture of the broader scope of the issue. I’ve taken note of the link/URL, and the specific OpenGL-related errors mentioned.
I'd like to delve deeper and verify specifics like the graphics models, precise driver versions, and any system errors. Utilizing the Intel SSU tool will enable me to collect detailed information about your system setup, which could aid in identifying the underlying cause of this issue.
Von M.
VonM_Intel
Hello Danyyy3l,
Von M.
Danyyy3l
Here's my SSU log:
VonM_Intel
Hello Danyyy3l,
Thank you for providing the SSU logs. In the meantime, I will need to do further research on this matter and post the response on this thread once available.
Von M.
Danyyy3l
Thanks for looking into this!
Please prioritize this issue. Yesterday I ran into a situation where my project was crashing so much that I literally couldn't properly do a simple revision for a client for like 3 hours, when in reality it could've taken me 10 minutes maximum if I didn't have all these crashes and export issues.
Literally just simply dragging a clip would cause crashes for no apparent reason
VonM_Intel
Hello Danyyy3l,
Thank you for your continued cooperation.
We’ve attempted to replicate the issue using the details and steps you provided, but so far, we have not encountered any crashes or segmentation faults during our testing. To assist you further and better understand the behavior you're experiencing, we kindly request the following:
  • A screen recording showing the exact steps that lead to the issue.
  • Any sample files or scripts that may help us reproduce the problem on our end
If you prefer not to share these materials publicly in the community, you’re welcome to send them privately via email. Your input will be invaluable in helping us identify the root cause and provide a resolution as quickly as possible. Please let me know how you would like to proceed.
Von M.
Danyyy3l
Hey, what email do I send it to?
VonM_Intel
Hello Danyyy3l,
I will be sending you an email shortly regarding this matter. Kindly reply to that email with the information I’ve requested.
Thank you.
Von M.
Danyyy3l
Hey,
I've replied to the email.
VonM_Intel
Hello Danyyy3l,
I just wanted to let you know that, as of now, we haven’t received a response to our previous email on our end. It's possible that the reply may not have gone through or was filtered out.
Could you kindly resend your message or let us know the approximate time it was sent? We'll make sure to double-check our system as well to ensure nothing was missed.
Von M.
Danyyy3l
Hey, I've resent the message.
My original was sent at: Sat, Jul 19, 12:41 AM (2 days ago)
Danyyy3l
Here's an update from the davinci-resolve side.
(I've gave them one of my project files and explained the issues I had just like here)
Danyyy3l
Any updates?
I've gotten an email confirming you've received the message.
Im still having issues with davinci resolve. A lot of freezes/crashes mid-editing and also mid-exporting.
I probably waste around 25% of the time editing just force closing and restarting davinciresolve due to this.
It's really frustrating, the last short-form video I made, i had to make a revision where I just had to cut-out like 3 seconds from the video, but it took me like literally 2 hours due to constant exporting freezes/resolve crashes.
If you need any more information apart from everything inside of this current post, and this post aswell:
https://community.intel.com/t5/Intel-ARC-Graphics/B580-Stability-Issues-with-DaVinci-Resolve-Missing-OpenGL-Entry/m-p/1695427?search-action-id=423926657671&search-result-uid=1695427
Let me know. Im willing to maybe even record my full editing process for a whole video if needed, and give the project file, just to show how incredibly often theres stability issues.
VonM_Intel
Hello Danyyy3l,
Thank you for following up and for sharing additional details about the difficulties you’re experiencing with DaVinci Resolve. I appreciate your patience. Just to confirm, have you received our previous email? If not, I’d like to share an important update: according to our team, this issue should be resolved in the latest DaVinci Resolve application update, which also includes a newer version of OpenVINO. I kindly ask that you update to the latest version of DaVinci Resolve and check if the behavior persists. Once updated, please let us know the results so we can continue assisting you as needed. If the problem continues even after updating, we’ll be glad to review any additional logs, files, or recordings you’re able to provide.
Von M.
VonM_Intel
Hello Danyyy3l,
Von M.
VonM_Intel
Hello Danyyy3l,
I have not heard back from you, so I will close this inquiry now. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Von M.
