Intel® ARC™ Graphics
3469 Discussions
Does Intel Arc B580 usable with AMD Ryzen 5 2400G ?
SonzoXide
Hi, guys.
My current PC spec is:
CPU: AMD Ryzen 5 2400G (ResizeBAR ON)
RAM: DDR4 Fury 2X8 3000MT/s
Mobo: AsRock B450M-HDV P4.7
Does it usable with Intel Arc B580 ? I know it prefers with PCIE 4.0, i mean like can i use it first before i upgrade other components for the next gen.
Thanks all.
SonzoXide
Hi guys.
I've just tried my pc spec with current stable bios version (P4.7).
My PC wont boot and short beep for 5 times.
I dont feel so comfort upgrade my bios to beta version.
and, i have also tried installing b580 on my friend's pc with 5700G cpu. and it works totally fine.
If anyone has same condition like me and find this thread. may help you guys.
I am really sorry for my broken english.
Also, Thanks for the replies!
AlHill
Here are the arc requirements:
https://www.intel.com/content/www/us/en/support/articles/000091128/graphics/intel-arc-dedicated-graphics-family.html
[W10 is this generation's XP]
Mynameforum
Check rebar in bios, if its compatible with your CPU or not.
Also:
"This processor has 12 PCIe lanes, 1x8 typically designated for a GPU and 4 additional lanes for storage"
Im using Arc card with Zen+ Ryzen 1600 AF 20 pci lanes rebar on. No problem.
AlHill
And that processor and motherboard still does not meet the hardware requirements.
SonzoXide
The rebar and above 4g encoding both already enabled.
i already disabled the csm. my storage is GPT too.
But, I can't find the ASPM setting like article mentioned.
SonzoXide
Does it mean my rig won't boot up at all?
Like my mobo speaker will short beep for 5 times.
Mynameforum
It should boot without any problem and PC will work, but CPU is weak spot, you need at least ryzen 3100 or better as official requirement says.
Intel cards does not have gpu scheduling for now, because of that CPU load is slightly bigger in games. So you need a good CPU.
Also make sure your motherboard bios updated because you will need update it anyway for future processor upgrade.
SonzoXide
Hi guys.
