Intel® Arc™ Discrete Graphics
3484 Discussions
Enshrouded - Setting Texture Resolution to Max. Quality crashes the game
Saveno
Saw reports on Steam Forums on Reddits about it so it doesn't seem to be an issue on my end but wanted to report it here as well. When you select Max. Quality for Texture Resolution in Graphics Settings the Game crashes and won't start anymore. Editing enshrouded_local.json and setting "textures": to "high" fixes it.
Catulpos_Intel
Hello Saveno,
I appreciate you posting a fix to a known issue of the game Enshrouded. To ensure that we have understand your query clearly, please provide the following information.
  • You mentioned that when you select max quality for texture resolution, the game crashes and won’t start, could you kindly confirm if you wanted to play the game at its maximum settings?
  • When did you first observe this issue?
  • Any recent hardware or software changes made on the device before the issue occurred?
  • Which game distribution service did you use?
  • Have you tried other troubleshooting steps aside from adjusting the game settings?
  • Please provide the SSU logs of your unit so we could peek at your system configuration and investigate the issue further. You can follow the instructions indicated on this article, How to get the Intel® System Support Utility Logs on Windows* and send the txt file here.
JCatulpos
Catulpos_Intel
Hello Saveno,
I just want to check if you were able to view the previous post and let me know if you have any inquiries.
Thanks, and have a nice day!
JCatulpos
VonM_Intel
Hi, Saveno.
I trust you're doing well.
I have not heard back from you we will close this inquiry now. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Von M.
