Intel® Arc™ Discrete Graphics
3627 Discussions
Fooocus: performance and memory errors
adolfotr
Hi, I'm having performance issues using Focusus (AI that generates images). I have a 16Gbyte Arc770.
In practice, the GPU memory is saturated, as if it were never emptied:
"RuntimeError: Could not allocate tensor with 117440512 bytes. There is not enough GPU video memory available!"
Do you have suggestions? Is there a way to do a memory wipe via command line or other utility?
ACarmona_Intel
Hello Adolfotr,
Thank you for posting in our Intel communities.
This can happen when the GPU memory isn't being released properly after tasks are completed, leading to insufficient memory for new tasks. I would like to know if you have tried to close any applications that are not in use while you try to use the Focus AI, as they may be occupying GPU memory.
Also, make sure that your GPU drivers are up to date. Driver updates often include fixes for memory management issues.
Thank you, and have a great day ahead!
Carmona A.
ACarmona_Intel
Hello Adolfotr,
We are checking in with you on the Focus AI issue to see if you have already performed the troubleshooting steps that we have provided or if you have any additional queries. Please know that we would be happy to assist you if you have any.
Thank you, and have a great day!
Carmona A.
ACarmona_Intel
Hello Adolfotr,
We are checking in with you, as we have not heard any response from you.
Carmona A.
adolfotr
Problem solved, thank you ^^
ACarmona_Intel
Hello Adolfotr,
We appreciate your updates and the time and effort you put into trying out our recommendations. I am truly happy to hear that the performance issue that we have with Focusus has been resolved!
We will now be closing our case since the issue that we have has already been resolved. If in the future you will need our assistance again, please submit a new question, as this thread will no longer be monitored.
Thank you, and have a great day ahead.
Carmona A.
