Intel® ARC™ Graphics
HDR Capture
Foddersin
Currently unable to capture video using Intel Arc Control on my Intel Arc A770 16GB LE.
  • Driver version: 31.0.101.4826
  • DDU has been used on every driver update
  • Note new beta driver is available to test
  • Intel Arc Control is affected
  • Intel SSU report is attached
  • A screenshot is attached
Steps to reproduce the problem:
  • Open Intel Arc Control
  • Go to Capture tab
  • Press start
Any assistance is appreciated.
Andres_Intel
Hello Foddersin,
Thank you for your patience.
I have worked on the reproduction of your issue and I have been able to replicated, the Capture feature currently doesn't work when the display has HDR turned on. We're looking to see if this can be enabled in a future Arc Control release but can't commit to any outcome yet.
For now, we will close this thread. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Andres P.
Andres_Intel
Hello Foddersin,
Thank you for posting on the Intel communities. I know is very frustrating when trying to record a video on Intel® Arc™ Control and receive error messages, it will be a pleasure to help you.
We released a new graphics driver this week, and I noticed on the Intel® SSU that the graphics driver is not updated, follow the steps below and let me know the results:
  1. Uninstall Intel® Arc™ Control by following the steps below
    1. Press the Windows key.
    2. Click on settings.
    3. Select Apps and then select Apps & features.
    4. Search for Intel® Arc™ Control software.
    5. Click on it and select the option to uninstall.
  2. Reinstall Intel® Arc™ Control by installing the graphics driver 31.0.101.4885. For guidance, on How to Install Intel® Arc Control.
Andres P.
Foddersin
Hi Andres.
I have already tried this, used DDU then rebooted and installed the latest 4885 Beta, exact same issue occurs.
Andres_Intel
Hello Foddersin,
Thank you for your answer, and for completing the steps.
I will start with an investigation to provide you with the next steps as soon as possible.
Andres P.
Foddersin
@Andres_Intel
Thanks for that.
I will patiently await your update.
Foddersin
@Andres_Intel
Problem still remains exactly the same in 4887.
Andres_Intel
Hello Foddersin,
Thank you for your time and for keeping me informed.
I will continue with the investigation, and now I will start with the reproduction as soon I have the results I will let you know.
Andres P.
Andres_Intel
Hello Foddersin,
Andres P.
