Intel® Arc™ Discrete Graphics
3643 Discussions
IDSA installs old driver
shue77
I have a ARC-770 and windows 11. When I check IDSA it says my GPU driver is up to date with version 32.0.101.6079. When I check my device manager, ARC control, and a driver updating tool they all say version 31.0.101.4502 is installed. If I update with the driver updating tool, IDSA says that the wrong drivers are installed.
On a side note ARC control fails the "check for update" function.
shue77
I should have read the sticky post at the top  first...
After reading through it, I used DDU and uninstalled the old drivers in safe mode. I then installed the current drivers from a fresh download, and it appears the ARC Control, IDSA, and Device manager all agree on the drivers installed.
shue77
