I've been facing issues after installing Intel Arc,
some applications have the layout blinking,
sometimes everything starts to turn black, until it is impossible to use anymore.
Or when it's not black, it's blurred, like in the pictures I'm going to put down here.
(the address bar in the browser and the edit menu in the office app)
Another thing, The sims 4 stopped working the anti-aliasing!
when i used "intel command center" I was able to put anti-aliasing on the sims 4 and it worked perfectly,
but since intel arc replaced intel command center, it stopped working...
*My drivers are properly updated, on Intel Arc I no longer have the option to adjust anti-aliasing, only the anisotropic filter
In other games, like: Point Blank, I'm abble to put anti-aliasing and it works perfectly!
my pc specs:
Acer Aspire A514-54
11th Gen Intel® Core™ i5-1135G7 @ 2.40GHz
Intel® Iris® Xe Graphics
Intel Arc 1.64.4583.3
Hello karlosamj
We understand you have contacted us directly through email support case with us, and we will continue to help you through that channel now. We will therefore close this community case. Please, keep in mind that this thread will no longer be monitored by Intel.
Thanks for your understanding.
Best regards
Jean O.
