I am trying to play Forza Horizon 4 again after a few months of inactivity but it keeps crashing on the load screen. It was working perfect before. I have noticed that on the system requirements, the VRAM is suddenly not enough, as can be seen below. This is despite the fact that I have set Forza Horizon 4 to using "High Performance - Intel Arc 370M" on its settings, and Intel Arc 370M should have 4GB of VRAM as stated in the requirements, otherwise I wouldn't have been able to download it in the first place.
Is there anyway I could get some help to increase the VRAM to what it was before?
Thank you.
Hello PluhPluh,
To get a better understanding of the issue and be able to provide an effective recommendation, please provide the missing key information here:
- Were you able to play this game, Forza Horizon 4, on this same system few months ago without any crashes?
- Were there any changes made prior to the issue?
- What is the graphics driver you are currently using?
- Which digital platform was your game (Forza Horizon 4) obtained from? (Steam, Epic, etc.)
- If possible, share the dump/log files if they are available.
- Kindly check our "Need help? Reporting a bug or issue with Arc GPU? - PLEASE READ THIS FIRST!" thread and follow the instructions for Crashing/freezing issues/BSOD.
Additionally, I highly appreciate you sharing your system configuration so I can fully check and provide you with an accurate fix. This could be possible by downloading the Intel® System Support Utility for Windows* software. When the download is complete, launch SSU.exe.
- Scan: Check the box Everything.
- Click Scan.
- Review: When finished scanning, click Next.
- Click Save. *Attach the SSU log file as you reply.
JeanetteC.
Hello PluhPluh,
Let us know if you have any questions.
JeanetteC.
Hello PluhPluh,
Since I haven't received any response from you recently, I will go ahead and close this thread. If you require help in the future, please submit a new inquiry, as this thread will no longer be monitored.
Sincerely,
JeanetteC.
