Intel® Arc™ Discrete Graphics
3688 Discussions
Intel Dedicated GPUs
CoolFlowProducts
   Hello, I am new to the Intel community! I am a PC enthusiast, I am also looking forward to building a new machine using Intel Graphics. I have a question, or maybe a suggestion.
   I have noticed that Intel does provide some additional knobs and dials for
Arc GPU users. I find that very nice. I think for enthusiasts, that is a definite perk.
   I have also noticed that within the software. There is no negative value for core voltage. I am not sure about frequency.
   I have also noticed, and this is not about one company has or does this and this one does not, but an additional change that I think could be helpful for enthusiasts. There are no memory settings. Maybe there is just a difference between GDDR6 and GDDR6X. But the frequency seems to be conservative, which is not a bad thing. I think frequency and voltage adjustments would be nice. The pricing for those cards is excellent. So a message for intel, Nice Work so far!
   So I am asking, is that something that could be a consideration for the future?
Or I am also asking, is that a change that could be made? Even though I know that is easier said than done.
Mike_Intel
Hello CoolFlowProducts,
  1. Can you tell us the model of your Graphics controller?
  2. Can you share some screenshots on where would you like us to add your suggestions?
  3. How these request change would help you as an end user?
Michael L.
CoolFlowProducts
   Thank you for your reply. I cannot tell you the exact model of the GPU I have as I do not have one. However, the questions apply to any ARC GPU that uses Arc Control Software.
   If you follow this link>    https://www.intel.com/content/www/us/en/products/docs/discrete-gpus/arc/software/arc-control.html
   You will find that within performance tab, configure settings, there are no negative values for CPU core voltage. There are positive values, which can help with an overclock, but negative values would allow an under-volt. Under volts allow power consumption to be brought down. Sometimes people underclock, when they do that, they do not necessarily need as much voltage. Sometimes, you can even run stock clocks or even overclocks with under-volts. I speculate that has to do with the specific silicon involved with the lottery. The manufacturer has to find a base and max voltage that would work across the board. Some silicon is better, the less efficient silicon requires higher voltages to run at the same frequencies. Negative values allow finer control of the Card the customer has acquired. I do not know if there is, or is not any binning involved in the cards that Intel sells.
   I did do some further research and found that the current Arc cards have GDDR6 installed, not GDDR6X. I have been watching you tube videos of Intel vs Nvidia cards. The Intel cards have been doing exceptionally well for a first Gen release from Intel within the standalone market. Drivers have also helped tremendously. What I noticed was the frequency of the memory between The intel Arc series vs the Nvidia cards such as the Nvidia RTX 3060ti. What I did not know was that some of them have GDDR6X, which allows far higher frequencies.
   I think the memory frequency settings from factory from Intel for the GDDR6 is already pretty good. However, I still think that it might be beneficial for enthusiasts who wish to fine tune there cards outside of factory settings, not necessarily above what is already standard.
   As someone who is interested in the line, who does not have any of the cards offered by Intel, I think some additional settings would just be useful or helpful for those who wish to further increase the performance or fine tune the operating characteristics of the cards. Unfortunately, some of what I ask does have the ability to cause artifact malfunctions or card crashes if an unexperienced user starts adjusting more advanced type of settings without the knowledge or understanding of what they are trying to achieve.
   If these settings were unlocked within the bios and additional code were written for the Arc Control software for the GUI for an additional area within the configure button for those reasons, it would probably be a good idea to label the settings as "advanced".
Mike_Intel
Thank you for the update.
Just to clarify, are you requesting or proposing that Arc Graphics should have settings to overclock or to tweak the Graphics cards performance in Arc Control?
Michael L.
Mike_Intel
Michael L.
CoolFlowProducts
   I was able to check the reply within email. I was momentarily locked out of my account. I have since created a new password. I wasn't proposing, only suggesting. I do not mean to be disrespectful, I felt as though I was fairly clear in saying that it could be helpful for enthusiasts to have settings that are a little more refined than just the settings that allow overclocking.
   Luckily, which I am excited about, there seems to have been updates or changes within arc control that have shown up with the release of the new B580. I was referring specifically to be able to turn clocks down, or voltages down in comparison to stock clocks and voltages. Which is not actually overclocking, as overclocking settings are already there.
   I was also suggesting memory adjustment, as those were not previously there, but now they are. I am pleased to find those new settings are available, as not memory, but other settings were and still are available through aftermarket software. Now however, users can just use factory software without the need to rely on aftermarket support.
Mike_Intel
I am sending another follow up on the information that I requested.
Michael L.
