Intel® Optimized AI Frameworks
Receive community support for questions related to PyTorch* and TensorFlow* frameworks.
Intel extension pytorch
AsterCrash
Estou tentando baixar o intel extension pytorch para usar o webui forge mas não estou achando ele para instalar e coloca-lo no webui para usar minha intel arc b580 para gerar imagens no webui no link na qual achei só versão pra linux mas eu uso o Windows 11
JedG_Intel
Hello AsterCrash,
The Intel® Extension for PyTorch* for GPU extends PyTorch with up-to-date features and optimizations for an extra performance boost on Intel Graphics cards.
The latest Intel® Extension for PyTorch* release introduces XPU solution optimizations. XPU is a device abstraction for Intel heterogeneous computation architectures, that can be mapped to CPU, GPU, FPGA, or other accelerators, and It's an open source project on GitHub* xpu-master branch.
Please try to access the links above and download the extensions. If you continue to observe the same issue, please let me know.
For reference: Intel® PyTorch Extension for GPUs
Best regards
Jed G.
AsterCrash
Show consegui instalar e rodar mas quando gero imagens no webui forge ele usa a cpu e não a gpu para acelerar
JedG_Intel
Hello AsterCrash,
Informamos que só posso apoiá-lo em inglês. Usei uma ferramenta de tradução da web para traduzir essa resposta, portanto, pode haver alguma tradução imprecisa.
Just to confirm, were you able to install the Pytorch extension? It appears that you are facing issues when generating images in Webui forge. To have a wider view of this, kindly share a photo of the issue.
Best regards
Jed G.
AsterCrash
How to check if it is installed? Sending the prints regarding the use of the CPU, it works but not with the arc b580 accelerating to create the image
JedG_Intel
Hi AsterCrash,
I really appreciate the photos. I'll be investigating this matter and I'll get back in touch as soon as I have an update.
Jed G.
JedG_Intel
Hello AsterCrash,
Upon review, to ensure you receive the most specialized assistance, we have a dedicated forum that addresses these specific concerns. Therefore, I will be moving this discussion to our AI Frameworks forum. This will allow our knowledgeable community and experts to provide you with timely and accurate solutions.
Best regards
Jed G.
Jing_Xu
AsterCrash
Attached is the output of the executed file
Jing_Xu
I can see pytorch and ipex 2.6 xpu are installed.
Please allow me to double-confirm your issue.
Did you get the workload running on GPU, but it ran slower than that on CPU? Or you didn't get it running at all on GPU, but only worked on CPU?
Jianyu_Z_Intel
@AsterCrash
  I checked this issue.
  You are using "webui forge" (https://github.com/lllyasviel/stable-diffusion-webui-forge) now.
  It's a project based on SD-WebUI 1.10.1 at this commit (July 2024).
  The "webui forge" doesn't mention it support Intel GPU, only support CUDA according to the project README.md.
  We can't make sure this project could support Intel GPU well.
   Since you are  using SD model, we recommend another tool [ComfyUI Windows Portable Package for Intel GPU|XPU] (https://github.com/YanWenKun/ComfyUI-WinPortable-XPU).
   It supports SD on Intel GPU, including BMG well.
   Could you try it?
  Thank you!
AsterCrash
Okay, I'll test this version of comfyui. If anything happens, I'll let you know.
Jianyu_Z_Intel
Any feedback of the answer?
Thank you!
