Intel® ARC™ Graphics
3451 Discussions
Low and unstable FPS in Dota 2 and League of Legends
Saveno
The issue:
Compared to my old 1660 Super my FPS in Dota 2 and League of Legends are rather low and unstable.
In Dota for example it varies between maybe 100 and 60 FPS. The 60 FPS low usually happen in Teamfights. When i check the Arc Control Panel it also shows that the GPU is not really much under load.
And despite looking much worse, i have similar results in League of Legends. At start my FPS are like at 200 but the more happens the worse it gets and it can also go as low as 60 FPS. And even if i go down to the lowest settings the FPS doesnt really change much.
It's kinda weird considering games like WoW, Black Desert Online and such are all running stable at 140+ FPS without any drops. FPS-wise AAA Games are also running as high as expected. It's just these 2 games that are running poorly for some reason.
My PC:
Ryzen 5 5600x
Arc A770 16GB
32 GB Ram
Both games are on SSDs
ReBar enabled
Driver: 31.0.101.4669
Nothing is overheating and i play both games on max settings on 1080p. Is it simply because they are Dx11 Games?
*edit
Something was wrong on my end. Can be closed or deleted. Sorry.
Jean_Intel
Hello Saveno,
I received your notification request that you would like to close this thread, so I am continuing to close the thread. If you need additional information, please submit a new question, as this thread will no longer be monitored.
Jean O.
