Intel® Arc™ Discrete Graphics
3563 Discussions
MSI Afterburner can't control the fan speed on my Intel B580 GPU. Any fixes or workarounds?
xmaojian
Just got my Maxsun Intel B580 GPU today, but ran into an issue—MSI Afterburner can’t adjust the fan speed at all. The only way to control it is through Intel’s Graphics Software, which is super inconvenient. Any idea when Intel’s drivers will properly support Afterburner?
Thanks!
Earl_Intel
Hi xmaojian,
I apologize for the inconvenience this may have caused you, but as of the moment, you can only adjust the fan speed settings on intel Arc Control.
You can also try contacting MSi if they integrated their MSi Afterburner application to take control of Intel Graphics Cards.
Earl E.
Earl_Intel
Hi xmaojian,
I just wanted to check if you had the chance to check my previous post regarding to your inquiry. In order for me to determine the appropriate course of action to address this issue, kindly inform me as soon as possible.
Earl E.
JedG_Intel
Hi xmaojian,
I would just like to clarify the information given by my colleague. You can adjust the fan speed using Intel Graphics Software. You may still refer to the link that was posted previously. Furthermore, please contact the OEM to see if the GPU can be controlled by MSI after burner.
Additionally, we have not heard back from you so I will close this inquiry now. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Jed G.
