Intel® Arc™ Discrete Graphics
3616 Discussions
OpenGL log spam in the console when playing Minecraft Java 1.21.5
djmrFunnyMan
New Contributor II
When playing the 1.21.5 minecraft update the console with be spammed with
OpenGL debug message: id=1282, source=API, type=ERROR, severity=HIGH, message='Error has been generated. GL error GL_INVALID_OPERATION in (null): (ID: 173538523) Generic error'
The issue has been reported to Minecraft developers. https://bugs.mojang.com/browse/MC/issues/MC-293754
Reproduction Steps:
- In the Minecraft Launcher go into the settings and enable "Open output log when Minecraft Java Edition starts"
- Start Minecraft 1.21.5
- Look into the output log to see the errors.
Alternatively if you didn't do step 1 you can see the output log by going to %appdata%\Roaming\.minecraft\logs\latest.log
I'm attaching an stacktrace of the error generated with Iris and PrismMC (the error is unchanged from vanilla minecraft)
This issue was introduced to minecraft 1.21.5 pre-release 2 to work around this issue. https://bugs.mojang.com/browse/MC/issues/MC-280482
It has some information in the comments that may be relevant to this issue.
Labels (2)
Gabriela_Intel
Hello! Thanks so much for your patience.
I can confirm that this issue is resolved with latest driver, 101.8132. Please give it a shot.
Gabriela E.
Graphics Support Engineer
djmrFunnyMan
New Contributor II
The attached file seems to be stuck in a virus scan forever. Reattaching it in the comments
djmrFunnyMan
New Contributor II
Comment has the same issue...
just have the text
[STDOUT]: [LWJGL] OpenGL debug message
	Source: API
	Type: ERROR
	Severity: HIGH
	Message: Error has been generated. GL error GL_INVALID_OPERATION in BindVertexBuffer: (ID: 2968384785) Generic error
	Stacktrace: knot//org.lwjgl.opengl.GL43C.glBindVertexBuffer(Native Method)
              knot//org.lwjgl.opengl.ARBVertexAttribBinding.glBindVertexBuffer(ARBVertexAttribBinding.java:78)
              knot//net.minecraft.class_10869$class_10871.method_68428(class_10869.java:136)
              knot//net.minecraft.class_10860.method_68353(class_10860.java:484)
              knot//net.minecraft.class_10860.method_68352(class_10860.java:480)
              knot//net.minecraft.class_10866.drawIndexed(class_10866.java:121)
              knot//net.minecraft.class_1921$class_4687.method_60895(class_1921.java:1086)
              knot//net.minecraft.class_4597$class_4598.method_60893(class_4597.java:96)
              knot//net.minecraft.class_4597$class_4598.method_22994(class_4597.java:85)
              knot//net.minecraft.class_4597$class_4598.getBuffer(class_4597.java:56)
              knot//net.minecraft.class_332.method_25295(class_332.java:451)
              knot//net.minecraft.class_332.method_52711(class_332.java:337)
              knot//net.minecraft.class_332.method_52713(class_332.java:359)
              knot//net.minecraft.class_332.method_52707(class_332.java:298)
              knot//net.minecraft.class_4264.method_48579(class_4264.java:31)
              knot//net.minecraft.class_8662$class_8664.method_48579(class_8662.java:34)
              knot//net.minecraft.class_339.method_25394(class_339.java:66)
              knot//net.minecraft.class_437.method_25394(class_437.java:124)
              knot//net.minecraft.class_442.method_25394(class_442.java:259)
              knot//net.minecraft.class_437.method_47413(class_437.java:113)
              knot//net.minecraft.class_757.method_3192(class_757.java:573)
              knot//net.minecraft.class_310.method_1523(class_310.java:1353)
              knot//net.minecraft.class_310.method_1514(class_310.java:936)
              knot//net.minecraft.client.main.Main.main(Main.java:265)
              net.fabricmc.loader.impl.game.minecraft.MinecraftGameProvider.launch(MinecraftGameProvider.java:480)
              net.fabricmc.loader.impl.launch.knot.Knot.launch(Knot.java:74)
              net.fabricmc.loader.impl.launch.knot.KnotClient.main(KnotClient.java:23)
              org.prismlauncher.launcher.impl.StandardLauncher.launch(StandardLauncher.java:105)
              org.prismlauncher.EntryPoint.listen(EntryPoint.java:129)
              org.prismlauncher.EntryPoint.main(EntryPoint.java:70)
RandyT_Intel
Hi djmrFunnyMan
Thank you for reaching out to our community. To help resolve your issue, I need some additional information. Regarding the virus scan, I'll send you an email so you can share the SSU log report, as I can't open attachments in the forum.
Please let me know:
  1. When did the issue start? Has it happened before?
  2. Are there any software and hardware changes made on the system?
  3. What is the make and model of your graphics card?
  4. What steps have you tried to fix the issue?
  5. Have you updated or reinstalled the game?
  6. Have you updated the graphics driver? If so, what version are you using?
  7. Did you do a clean installation of the graphics driver?
I can't access the link you provided because it requires login credentials. Could you share any insights from the game developer or discussions from the link? If possible, paste the specific report link here.
Once I have this information, we can begin investigating. Looking forward to your response.
Randy T.
djmrFunnyMan
New Contributor II
I apologize for the oversight regarding login credentials. I have updated my original report with links that do not require login. (mojang recently moved bugtrackers and the new one is quite messy)
Though fyi you can just create a free account there at any moment, just enter an email and if it doesn't have an account assigned to it it'll redirect you to the signup page.
As for the other questions
1. The issue started with Minecraft Java update 1.21.5 (it was not caused by a driver update)
2. No
3. Sparkle B580
4. The issue could be theoretically resolved by creating a mod to disable the Mesa workaround they added. That is too complex for me to do however.
5. Yes I have updated the game. The issue appears in the newest update
6. I'm on the latest drivers (not WHQL certified)
7. Yes
To reiterate an important piece of information the issue is caused by mojang's workaround for a critical bug with Mesa 25.0 (that's what bug report MC-280482 is about)
RandyT_Intel
Hi djmrFunnyMan,
Thank you for sharing this information. I will begin investigating the issue. I'll post an update here or notify you directly once there are any developments. If I need further details, I'll reach out to you here. I appreciate your patience as I work on this matter.
Randy T.
RandyT_Intel
Hi djmrFunnyMan,
I just wanted to clarify if the error message is only happening when using the launcher (PrismMC). Have you tried launching the game independently? however if I'm not mistaken this game requires launcher. If this issue is not driver-related, it might be best to check internally or consult the appropriate forum for steps to resolve this concern.
Randy T.
djmrFunnyMan
New Contributor II
You are misunderstanding. This error is also present with the official launcher. However launching it with the 3rd party launcher allows it to generate a stacktrace which is probably useful so I attached it as well.
RandyT_Intel
Hi djmrFunnyMan,
Thank you for the clarification. I will check the error message internally to see if we can do something about it. I will look into the issue further. I will provide an update as soon as possible.
Randy T.
Gabriela_Intel
Hey there @djmrFunnyMan. We've filed a bug report for your issue. Please note that it may take a while before we provide another update again while the issue is getting investigated. We'll post something in this thread once we have an update to share.
Thanks!
Gabriela_Intel
Gabriela E.
