I have an A770 8GB GPU to run Hogwarts Legacy. Recently, I upgraded the driver into new 4314 WHLQ version, then Hogwarts Legacy met serious performance problems, including unstable FPS, frozen and low GPU activity rate (Only 60%-70%).
Tried 4335 beta driver, the problems are still there.
Finally, I degraded the driver into 4146, then the problems are solved. The GPU activity was back to 90%-100% and FPS because stable.
It is noted all tests kept the same setting in the game and tested in the same scenarios of game.
Thanks for your help.
Hello ninmiao
thank you for posting on the Intel® ARC™ Graphics Communites. I am sorry you are experiencing performance issues when playing Hogwarts Legacy on your system.
I see that you have tested the latest BETA and WHQL drivers. If not done yet, please do a clean installation of the same driver by installing the current version using Display Driver Uninstaller, and once uninstaller and while in safe mode install and test either version 31.0.0101.4335 or 31.0.101.4314.
If the issue still happens, share with us the following information:
- Share a short video showing the issue.
- Share a screenshot of the in-game graphics settings.
- What distribution service was the game downloaded from?
- Create a log file with the Intel® System Support Utility and attach it to your response to get more information about the hardware configuration.
Hugo O.
Hello ninmiao
I hope you are doing fine.
Hugo O.
Hello ninmiao
I have not heard back from you. So I will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Hugo O.
