Intel® ARC™ Graphics
3463 Discussions
Poor performance in HELL LET LOOSE and low GPU usage
wawajiao
Performance of A770(16G) in HELL LET LOOSE is poor and GPU usage is around 50%
Andres_Intel
Hello wawajiao,
Thank you for posting on the Intel communities. I see that you are having performance issues while playing Hell Let Loose with your Intel® Arc™ A770 Graphics (16GB). As a gamer I understand that we always want the game to run fluently, I will be glad to help you.
To have a better understanding of the situation, please answer the following questions:
  • Is the graphics card an Intel Branded Card or is it from another brand?
  • What tool did you use to check the GPU usage?
  • Take screenshots of the game settings, in case we need them to replicate the issue.
  • Are there FPS drops or low FPS? If so, what is the FPS the game is running at?
  • To know your software and hardware information, download and attach the report for the following tool Intel® System Support Utility for Windows (SSU), you can find the steps on the link How to get the Intel® System Support Utility Logs on Windows.
Andres P.
Andres_Intel
Hello wawajiao,
Were you able to generate the report of the Intel® SSU to check your system environment?
Andres P.
Andres_Intel
Hello wawajiao,
Andres P.
