Intel® ARC™ Graphics
2314 Discussions
Problem with graphic card arc750 asrock model
Destinyhub777
Hello there , i have a problem with graphic card arc750 model by asrock , the vram clock stays blocked on 2000 mhz even on idle ...will it affect the videocard ? it is normal to stay blocked on that frequency ? and one more problem..i can t solve the gpu core power consumption and it stays on 41watts on idle constantly ..can you give me a answer please ?
Thank you
Hugo_Intel
Hello Destinyhub777
Thank you for posting on the Intel® ARC™ Graphics Communities. I am sorry to hear that you are experiencing issues related to power and clock speeds on Intel® Arc™ A750.
Please follow the steps in the following article to optimize power settings on the GPU:
High Power Consumption when Intel® Arc™ Graphics Card is Idle
If the issue continues to happen please let me know the following:
Hugo O.
Carlos_L_Intel
Hi @Destinyhub777
Carlos L.
Carlos_L_Intel
Hi @Destinyhub777
We have not heard back from you, so we will close this thread. If you need any additional information, please submit a new question, as this thread will no longer be monitored.
Carlos L.
Carlos_L_Intel
Hello @Destinyhub777
 Thank you for your time. The VRAM Clock showing max speed at all times is expected behavior.
 Please take a look at the following information: https://github.com/IGCIT/Intel-GPU-Community-Issue-Tracker-IGCIT/issues/161
Carlos L.
