Intel® Arc™ Discrete Graphics
3680 Discussions
Red Dead Redemption 2 DirectX 12 Problem
addelucas123
New Contributor II
Good night
I'm going to open a new thread to talk about the problem I'm having in Red Dead Redemption 2 when using DirectX 12; The problem I have in Red Dead Redemption 2 is worth the problem I have in Red Dead Redemption 2 when I put or rather when I use DirectX 12 with vertical sync and 144Hz it throws me or gives me 1 FPS, I must deactivate vertical sync and 50Hz and I get 50 to 60 FPS, and I would like to sometime get meta drivers to correct the DirectX 12 problem in Red Dead Redemption 2, the GPU I have Intel Arc A770 16GB is modern and performs better with modern DirectX 12 API, If not You comply, you are not doing anything, So please correct the problem, I did a clean uninstallation of the drivers and the game, and I reinstalled from scratch but the problem remains the same, 1 FPS when activating the 144Hz vertical synchronization, I have to use 50Hz and disable synchronization. I put 144Hz and vertical synchronization disabled, it applies it but when I go back to the graphics menu it says 50Hz, come on, 1 FPS is unplayable, so please get to work with a lot of love, dear, respect, but red dead redemption 2 is a great game and the only thing that fails is DirectX 12, I would like the Intel drivers engineers to fix it or read it, that's the only thing I ask.
Beforehand
David
Hugo_Intel
Hello addelucas123
Thank you for posting on the Intel® ARC™ Graphics Communites.
We apologize for the time it has taken so far for this issue to be resolved, we know it is important for you to be able to play this popular title at a high refresh rate. At the moment this is an issue we are still working on and there is no estimated time for a fix to come up, but please know we are working on this performance issue.
Hugo O.
addelucas123
New Contributor II
Okay, sorry, then I'll stay calm and ready, but I hope the next update, please I want that performance to surpass the Intel Arc A770 LE to the RTX 3060 Ti by 10% in DirectX 12, I would also like if it could be what happened with the problem or what problem it is more or less to know more or less what it is
Lu_qwq
The Intel Arc b580 graphics card encounters an unknown error ffffff when playing Red Dead Redemption 2 using Vulkan, lower FPS with DX12. Instability and lower frame rates in Devil May Cry with DX12, while DX11 has terrain flickering or display bugs. How to resolve this?
Hugo_Intel
Hello addelucas123
Thank you for your understanding. All we can share at the moment is that we continue to work on this performance issue with Red Dead Redemption and to please look forward to future driver updates. We also continue to release pretty constant driver updates to continuously improve performance in a broad range of titles. Once again than you for your patience and support.
Hugo O.
addelucas123
New Contributor II
Okay, well, let's make a deal, if that's okay with you, go ahead. I told Rockstar the technical support company to implement Intel Intel Intel engineers to communicate through Red Dead Redemption 2 internally so that it implements the technology the same as it did with NVIDIA, well Intel the same, and also Hugo please the Intel ARC A770 LE 16GB graphics, I only ask that it surpasses that graphics okay in modern games in triple AAA DirectX 12 at least Intel Arc A770 LE 16GB should exceed 10% RTX 3060 TI and already catch up with fighting Intel Arc A770 with an RTX 3070 in some games, nothing I ask for then apologies if it is working I'm not sorry for saying it, but I have to say it to correct myself hehehe, I hope Intel Arc A580, I've seen the video and it surpasses the RTX 3050 and I think, Intel I think it will surpass Arc A580 RTX 3060 or equal it, I know that You are going to do it. Nothing, I only ask that you improve the stability and performance of both the CPU and GPU in communication to get the most out of it. By the way, I am still pending Days Gone at night the performance drops and some areas drop from 35 FPS to 100 FPS, the video does not It is necessary because you have it. Well, I hope to update Intel Arc drivers in the next few months. I am happy with my Intel Arc A770 LE GPU. They listened to me and lowered the price. The performance is superior to an RTX 3060 TI and I think you can surpass an RTX. 4060 which is inferior to an RTX 3060 Ti, so go for them!
addelucas123
New Contributor II
I also wanted to comment that you should correct the FPS drop performance issue at night in Red Dead Redemption 2, another thing apart from the problem of Red Dead Redemption 2, I would like that when the problem is solved, I would like it to be possible to play ultra ultra without activate MSAA and finally tessellation, and I would like it to be possible to play between 110 FPS and 115 FPS with FHD 1920x1080, and to play QHD 2K 100 at 90 FPS, that is what I would like to be able to play that amount, which is a lot FPS, well between 100 and 110 FHD 1920X1080,
Hugo_Intel
Hello addelucas123
We believe our Intel® Arc™ A770 card is a pretty robust and competitive GPU and we appreciate you are taking advantage of its capabilities, please look forward to future driver updates that will continue to improve performance in many different games.
In case you have a performance issue in Days Gone, please open a new thread so we can troubleshoot and ask for information accordingly.
Hugo O.
Hugo_Intel
Hello addelucas123
We noticed there are no further questions related to this topic as well we noticed you opened a new thread for the Days Gone issue so in this case we will proceed to close this thread. As previously informed we continue to work on the performance problem in Red Dead Redemption 2 at the moment there is no estimated time for the issue to be resolved but please look forward to future driver updates.
Hugo O.
addelucas123
New Contributor II
I have another problem with Red Dead Redemption 2 with Vulkan and I also ask other things to know if it is okay, that is, normal or not, that's why I open a new one so that it can tell me yes or no, but I already know DX12 is in them, but now it is Vulkan performance issue Vulkan
Hugo_Intel
Hello addelucas123
Please let's keep one issue per thread in order to avoid confusion, as per the title this thread is related to the performance in Red Dead Redemption 2 when using DX12 specifically. If you are experiencing performance issues when using the Vulkan API in the game, please open a new thread so we can request information according to that problem. Thank you for your understanding.
Hugo O.
