Intel® ARC™ Graphics
3456 Discussions
Sniper Elite 3 B580 horrible texture artifacts linux only
-crash-
I am getting very bad texture/shadow artifacts when attempting to play this game on linux. There are no such issues on windows 11.
Game: Sniper Elite III via Steam
Game settings: Ultra game preset (although this happens under any setting presets and resolutions)
PC: i7-13700 with ReBAR enabled, 32G RAM, NVME drives
Os/Drivers:
- Windows 11 - latest available, as of 2025-10-20
- Mint 22 (Ubuntu 24.04) - Mesa 25.0.7, latest available from Intel PPA (see screenshot for details)
Example videos:
Win 11
Linux
KennethB_Intel
Hello -crash-,
Thank you for reaching out to the Intel Community Forum. I understand you're experiencing severe texture and shadow artifacts when playing Sniper Elite III on Linux, while the same issue does not occur on Windows 11. I would like to gather more information to help investigate this further:
  • When did this issue start happening?
  • How often does the issue occur—does it happen immediately upon launching the game or after a certain period?
  • Have there been any recent changes to your system, such as OS updates, driver updates, or new software installations?
  • Have you tried using different versions of the Mesa driver or switching to a different kernel version?
  • Could you please provide an SSU log of your system? You can find instructions on How to get the Intel® System Support Utility Logs on Windows*
Please provide these details so I can further assist you in identifying the root cause of the issue.
Thank you.
Kenneth B.
-crash-
It happens immediately when starting the game. This is a new game to me, so I don't know if it's a recent change. As part of the attempts to fix it, I added the Intel PPA and upgraded the drivers from there. I have not tried switching kernels.
Do you actually want me to run SSU on windows?
KennethB_Intel
Hello -crash-,
Apologies for the confusion regarding the SSU. Please run the Intel® System Support Utility for the Linux* Operating System so we can further investigate this.
Also, if possible, please try sharing a video of the issue.
Kenneth B.
-crash-
Kenneth, the links to videos are linked in the original post.
SSU is attached.
KennethB_Intel
Hello -crash-,
Thank you for providing the SSU logs. Please allow me some time to conduct a more thorough internal investigation to better understand the issue and identify the appropriate steps to take.
I will make sure to provide you with an update as soon as possible once I have more information to share.
Thank you.
Kenneth B.
KennethB_Intel
Hello -crash-,
May I kindly ask if you have already tried using different Linux drivers to see if the issue persists?
Additionally, I recommend updating your BIOS to version 7E01vMF. This may help resolve the issue you are encountering.
Please let me know the results after performing these steps so I can continue assisting you further.
Thank you.
Kenneth B.
-crash-
Hello.
I have just updated the BIOS and there is no difference.
I had tried playing with one prior driver version, and there was no difference.
KennethB_Intel
Hello -crash-,
Thank you for your update and for confirming that updating the BIOS and trying a previous driver version did not resolve the issue.
To help replicate and investigate the texture and shadow artifacts further, may I kindly ask for the following additional details:
  • Have you tried launching the game with any specific launch options or environment variables?
  • Are you using any third-party tools while running the game?
  • Could you please share with us the in-game settings you are using?
  • Have you tried resetting the BIOS settings to their default settings?
  • Are you able to try different graphics driver versions? If so, could you please confirm which driver versions you have already tried?
I will wait for your response so I can continue assisting you further Once I receive your response, I will conduct further internal investigation.
Thank you.
Kenneth B.
-crash-
I've narrowed it down to a shadow problem, because that is the only setting that makes a difference. If I set shadows to "low", they still glitch and flicker terribly, but there are fewer of them.
None of the other display settings make any difference.
- no launch options
- no 3rd party tools
- steam overlay off/on makes no difference
- this happens at all resolutions
- resetting the bios does nothing
- as I said, this happened on the prior driver version, but I don't know the number
Are you able to reproduce this issue?
KennethB_Intel
Hello -crash-,
Thank you for your detailed response. Please allow me to perform an internal investigation. I'll get back to you as soon as I have available information.
Thank you!
Kenneth B.
