Intel® Arc™ Discrete Graphics
3557 Discussions
SteamVR became brick on latest Graphics driver
_C4t633k3r
I installed the latest driver (101.6559) and SteamVR stopped working. I use Arc A770 16 GB which works fine with SteamVR for a year. Rollbacking the driver to older version, it came back life again, so I doubt the latest driver is malfunctioning.
Labels (2)
JeanetteC_Intel
Hello _C4t633k3r,
To understand the issue better, please help share the following details below:
1) Provide the driver version that worked fine with your Intel® Arc™ A770 Graphics (16GB) and SteamVR.
2) Is the rollback option from the driver properties on the device manager still available?
3) How did you install the latest driver (6559)? Was it a manual installation or used a driver updater tool?
4) Please help share your system configuration so I can further investigate on what's Causing the system. This could be possible by downloading the Intel® System Support Utility for Windows* software. When the download is complete, launch SSU.exe.
  • Click Scan.
  • Click Save (.txt).
  • Attach the log file as you reply.
I will wait for your reply.
JeanetteC.
Intel Customer Support
JeanetteC_Intel
Hello _C4t633k3r,
Have you seen my previous post?
Let us know if you have any questions.
JeanetteC.
JeanetteC_Intel
Hello _C4t633k3r,
I have not seen any new posts from you for the past few days. I'll proceed in closing this case now.
Sincerely,
JeanetteC.
