Intel® Arc™ Discrete Graphics
3515 Discussions
TFLOPs on new Intel Arc GPUs
farah
I am wondering if there is a way either calculate (specifications sheet attached) or look up the TFLOPs computing power for the new Intel Arc Series:  A350M, A730M, A770M, A370M, A550M
I am needing this information to do a product comparison/selection.
David_G_Intel
The peak clock for all 5 notebook SKUs are in the table below:
SKU | Peak Clock
A770M 2050Mhz
A730M 2050Mhz
A550M 2050Mhz
A370M 2050Mhz
A350M 2200Mhz
Each vector engine supports 16 FP32 ops/clk.
Hence A370M supports peak 16 * 128 * 2050= 4.198TFLOPS. Where 128 is the number of Vector Engines enabled on A370M. Let us know if you have any questions.
David G
David_G_Intel
Hello @farah
Thank you for posting on the Intel️® Arc communities. This information is not publicly available right now for the released cards, I will investigate and post the updates on the thread.
David G
David_G_Intel
SKU | Peak Clock
A770M 2050Mhz
A730M 2050Mhz
A550M 2050Mhz
A370M 2050Mhz
A350M 2200Mhz
David G
David_G_Intel
David G.
David_G_Intel
David G.
farah
Thank you for the help!
